Inleiding
This is a guide to replace the keyboard on the Lenovo Thinkpad T14 gen 3.
Wat je nodig hebt
Start by disabling the internal battery in the BIOS.
You can enable the battery again by connecting the included power adapter.
If you choose to skip this step, make sure that the laptop is fully powered off before you start to avoid damaging anything.
Slide the keyboard up until the tabs at the bottom are free.
Try not to press any of the keys or it will be difficult to slide.
Lift the bottom slightly and pull out from the frame.
Once you have it out, fold it down on the frame.
Using a spudger or your fingernail, carefully disconnect the two cables connecting the keyboard to the motherboard.
8 andere personen hebben deze handleiding voltooid.
Één opmerking
Danke
nun braucht man auch kein spezialwerkzeug mehr wie bei den alten T14
Thanks
now you don't need any special tools like with the old T14
