Ga door naar hoofdinhoud
Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement, Hard Disk Drive: stap 1, afbeelding 1 van 2 Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement, Hard Disk Drive: stap 1, afbeelding 2 van 2
    • Remove the 8 screws that hold down the back panel using the Phillips #000 screwdriver.
  2. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: stap 2, afbeelding 1 van 1
    • Remove the two M2 x 3 mm, wafer-head, nylon-coated screws that hold down the hard drive assembly using the Phillips #0 screwdriver.
  3. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: stap 3, afbeelding 1 van 1
    • Pull the hard drive assembly out with backside up.
  4. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: stap 4, afbeelding 1 van 1
    • Remove the four M3 x 3 mm, flat-head, nylon-coated screws on the side of the hard drive assembly using the Phillips #0 screwdriver.
  5. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: stap 5, afbeelding 1 van 1
    • Gently, remove the plastic cover with the blue strips.
  6. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement, HDMI-USB Jack assembly: stap 6, afbeelding 1 van 2 Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement, HDMI-USB Jack assembly: stap 6, afbeelding 2 van 2
    • Remove the 3 screws holding down the T shaped cover using the Phillips head #1. Two of the screws are M2.5x 4 wafer head. The other is a M2x4MM.
    • The two similar screws have blue threading around them.
  7. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: stap 7, afbeelding 1 van 2 Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: stap 7, afbeelding 2 van 2
    • Use the opening tool to lift up the T shaped cover.
    • Remove the M2x3MM wafer head screw.
  8. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: stap 8, afbeelding 1 van 3 Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: stap 8, afbeelding 2 van 3 Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: stap 8, afbeelding 3 van 3
    • Take off the 2 M2x3MM wafered screws holding down the chip top of assembly.
    • Lift the chip to release the HDMI-USB jack assembly
  9. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: stap 9, afbeelding 1 van 1
    • Detach the connector.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 6
Altijd: 298
