Ga door naar hoofdinhoud
Lenovo ThinkPad L440 Hard Drive Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad L440 Hard Drive Replacement, Battery: stap 1, afbeelding 1 van 3 Lenovo ThinkPad L440 Hard Drive Replacement, Battery: stap 1, afbeelding 2 van 3 Lenovo ThinkPad L440 Hard Drive Replacement, Battery: stap 1, afbeelding 3 van 3
    • Open the laptop to access the power button.
    • Hold the power button in the top right until the computer powers off.
    • Turn the computer over so that the bottom of the computer is facing up
  2. Lenovo ThinkPad L440 Hard Drive Replacement: stap 2, afbeelding 1 van 1
    • On the left side under the raised surface, move the tab to the left towards the unlocked symbol. Repeat this on the right side and move the tab to the right towards the unlocked symbol.
  3. Lenovo ThinkPad L440 Hard Drive Replacement: stap 3, afbeelding 1 van 2 Lenovo ThinkPad L440 Hard Drive Replacement: stap 3, afbeelding 2 van 2
    • From the top of the laptop, slide the raised surface away from the rest of the laptop and out of its slot to remove the battery from the computer.
  4. Lenovo ThinkPad L440 Hard Drive Replacement, Back Panel: stap 4, afbeelding 1 van 2 Lenovo ThinkPad L440 Hard Drive Replacement, Back Panel: stap 4, afbeelding 2 van 2
    • Loosen the four retainer screws on the bottom of the laptop using a Phillips #0 screwdriver.
    • These four screws are attached to the panel with washers, so they will spin freely when they are loose and will come off with the panel.
  5. Lenovo ThinkPad L440 Hard Drive Replacement: stap 5, afbeelding 1 van 2 Lenovo ThinkPad L440 Hard Drive Replacement: stap 5, afbeelding 2 van 2
    • With your fingers, lift up the back panel from the left side.
  6. Lenovo ThinkPad L440 Hard Drive Replacement, Hard Drive: stap 6, afbeelding 1 van 2 Lenovo ThinkPad L440 Hard Drive Replacement, Hard Drive: stap 6, afbeelding 2 van 2
    • Remove the single 3.5 mm screw next to the hard drive using a Phillips #00 screwdriver.
    • Remove the hard drive from the laptop.
Conclusie
Kristen Gismondi
92.132 Reputatie
241 handleidingen geschreven
iFixit Lid van iFixit
Staff
118 Leden
19.465 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 29
Altijd: 56
