Ga door naar hoofdinhoud
Lenovo ThinkPad Helix Battery Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad Helix Battery Replacement, Screen: stap 1, afbeelding 1 van 1
    • Using a plastic opening tool or opening pick, gently pry the screen off.
    • If possible, use plastic tools to pry the screen, as the metal tool as shown in the image can potentially damage your device.
    • You will need to use a little bit of force to pry it open. There is little indent that goes around the tablet. You will insert your tool between this indent and pry it open.
    • Once you're able to lift a little bit of the screen away from the tablet, work your way around until screen is separated from tablet. Stop for step two.
  2. Lenovo ThinkPad Helix Battery Replacement: stap 2, afbeelding 1 van 3 Lenovo ThinkPad Helix Battery Replacement: stap 2, afbeelding 2 van 3 Lenovo ThinkPad Helix Battery Replacement: stap 2, afbeelding 3 van 3
    • Lift the screen up slowly.
    • Once separated, you can not fully take it off due to some cable connections.
    • Open the clips of the ZIF connectors and gently grab the cable to pull it out.
  3. Lenovo ThinkPad Helix Battery Replacement: stap 3, afbeelding 1 van 1
    • Once the cables are disconnected, remove the screen.
  4. Lenovo ThinkPad Helix Battery Replacement, Battery: stap 4, afbeelding 1 van 1
    • Using a Phillips #00 screwdriver, unscrew the four nylon-coated 3 mm screws holding the battery in place.
  5. Lenovo ThinkPad Helix Battery Replacement: stap 5, afbeelding 1 van 2 Lenovo ThinkPad Helix Battery Replacement: stap 5, afbeelding 2 van 2
    • Disconnect the battery cable from the motherboard.
    • Lift the battery out of the device.
Conclusie
7 andere personen hebben deze handleiding voltooid.
Manuel Parra Rocha
494 Reputatie
2 handleidingen geschreven
Gateway, Team S1-G6, Saknee Fall 2019 Lid van Gateway, Team S1-G6, Saknee Fall 2019
GCC-SAKNEE-F19S1G6
4 Leden
3 handleidingen geschreven
Één opmerking
Hi, would you possibly have an explanation as to why a replacement battery is still not charging and yielding error messages? Thank you.
M.H. L. - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 82
Altijd: 6,849
