Ga door naar hoofdinhoud
Lenovo ThinkPad HK11e Battery Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad HK11e Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Make sure the Lenovo laptop is shut off.
    • Turn over laptop and lay it on its face exposing the back-plate screws.
  2. Lenovo ThinkPad HK11e Battery Replacement: stap 2, afbeelding 1 van 1
    • Find the six screws that hold together the back plate.
    • Carefully unscrew the six 3.3 mm screws that fasten the back plate using the T5 Torx screwdriver.
  3. Lenovo ThinkPad HK11e Battery Replacement: stap 3, afbeelding 1 van 1
    • Use a plastic opening tool or a spudger to carefully remove the back plate.
  4. Lenovo ThinkPad HK11e Battery Replacement: stap 4, afbeelding 1 van 1
    • Battery is located in the bottom right portion of the laptop.
    • Find the three screws that mount the battery.
    • Carefully unscrew the three 3.5 mm screws that fasten the battery down using the T5 Torx screwdriver.
  5. Lenovo ThinkPad HK11e Battery Replacement: stap 5, afbeelding 1 van 1
    • Notice a connector that joins the battery to the laptop.
    • Slowly disconnect the connector by pulling back on the six-wire harness.
  6. Lenovo ThinkPad HK11e Battery Replacement: stap 6, afbeelding 1 van 1
    • Remove the battery from its assigned location.
  7. Lenovo ThinkPad HK11e Battery Replacement: stap 7, afbeelding 1 van 1
    • Reverse steps to mount new battery correctly.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 125
Altijd: 801
