Ga door naar hoofdinhoud
Lenovo ThinkPad Edge E530 HDD Replacement
Wat je nodig hebt
Video overzicht
  1. Lenovo ThinkPad Edge E530 HDD Replacement, HDD Cover: stap 1, afbeelding 1 van 3 Lenovo ThinkPad Edge E530 HDD Replacement, HDD Cover: stap 1, afbeelding 2 van 3 Lenovo ThinkPad Edge E530 HDD Replacement, HDD Cover: stap 1, afbeelding 3 van 3
    • Switch-off the Laptop and remove the battery.
    • The HDD/Memory Cover is held by 3x Phillips screws. Remove them.
    • Remove the Cover.
  2. Lenovo ThinkPad Edge E530 HDD Replacement, HDD (Hard Disk Drive): stap 2, afbeelding 1 van 3 Lenovo ThinkPad Edge E530 HDD Replacement, HDD (Hard Disk Drive): stap 2, afbeelding 2 van 3 Lenovo ThinkPad Edge E530 HDD Replacement, HDD (Hard Disk Drive): stap 2, afbeelding 3 van 3
    • There are 2 x philips screws, securing the HDD Caddy Case. Remove them and slide the HDD to disconnect it from the SATA Connector.
    • The Caddy Case is held to the HDD by 4x Phillips screws. Remove them and separate the HDD from the case.
    • After installing the new HDD you must install a new OS or clone your old HDD.
    • You can install SATA HDD, 2.5" up to 1TB.
    • Did you do it successfully?
Conclusie
7 andere personen hebben deze handleiding voltooid.
ZFix
191.055 Reputatie
330 handleidingen geschreven
Master Techs Lid van Master Techs
Community
322 Leden
2.506 handleidingen geschreven
2 opmerkingen
Since you mention cloning, it would be good to know how to clone one’s old drive. Would this also clone any errors on the oldrive and then put them on the new drive???
David Abineri - Antwoord
Thanks for the guide. It also works for the ThinkPad Edge E531 model.
Célestin Taramarcaz - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 18
Altijd: 10,171
