Ga door naar hoofdinhoud
Lenovo ThinkPad Edge E530 Fan / Cooling System Replacement / Cleaning
Wat je nodig hebt
Video overzicht
  1. Lenovo ThinkPad Edge E530 Fan / Cooling System Replacement / Cleaning, HDD Cover: stap 1, afbeelding 1 van 3 Lenovo ThinkPad Edge E530 Fan / Cooling System Replacement / Cleaning, HDD Cover: stap 1, afbeelding 2 van 3 Lenovo ThinkPad Edge E530 Fan / Cooling System Replacement / Cleaning, HDD Cover: stap 1, afbeelding 3 van 3
    • Switch-off the Laptop and remove the battery.
    • The HDD/Memory Cover is held by 3x Phillips screws. Remove them.
    • Remove the Cover.
  2. Lenovo ThinkPad Edge E530 Fan / Cooling System Replacement / Cleaning, Fan / Cooling System: stap 2, afbeelding 1 van 3 Lenovo ThinkPad Edge E530 Fan / Cooling System Replacement / Cleaning, Fan / Cooling System: stap 2, afbeelding 2 van 3 Lenovo ThinkPad Edge E530 Fan / Cooling System Replacement / Cleaning, Fan / Cooling System: stap 2, afbeelding 3 van 3
    • Disconnect the Fan cable.
    • Remove the 2x screws from the Fan module.
    • Unscrew 4x screws around the processor.
    • Carefully lift the Cooling System.
  3. Lenovo ThinkPad Edge E530 Fan / Cooling System Replacement / Cleaning: stap 3, afbeelding 1 van 3 Lenovo ThinkPad Edge E530 Fan / Cooling System Replacement / Cleaning: stap 3, afbeelding 2 van 3 Lenovo ThinkPad Edge E530 Fan / Cooling System Replacement / Cleaning: stap 3, afbeelding 3 van 3
    • Use a lint-free cloth and isopropyl alcohol to clean the old thermal compound.
    • If the thermal compound is solidified, you can use a flat end of any plastic tool to scrape it off.
    • Separate the Fan from the Heat-sink.
  4. Lenovo ThinkPad Edge E530 Fan / Cooling System Replacement / Cleaning: stap 4, afbeelding 1 van 1
    • Use a soft anti static brush and clean the Heat-sink on the inside.
    • Before installing a new Cooling System or reinstalling the old one, you must clean the processor from the old thermal compound and put a new one.
Conclusie
3 andere personen hebben deze handleiding voltooid.
ZFix
191.329 Reputatie
330 handleidingen geschreven
Master Techs Lid van Master Techs
Community
322 Leden
2.539 handleidingen geschreven
3 opmerkingen
Very, very well done video on this guide for the Lenovo Thinkpad e530 laptop.
My compliments to the author of this guide.
James Harnsberger - Antwoord
will i need thermal paste to do this?
dErpyto3z Eeee - Antwoord
thanks its clear
Kayan Dev - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 15
Altijd: 8,020
