Inleiding
This guide will help you to change your storage drive for Lenovo ThinkPad E470 in an easy and safe way.
Storage drives is used for sorting and retrieving data. Due to personal use or work requirement people needs more storage and faster read and write speed for their computer, change to a larger SSD will be a faster and cheaper choice than connect to a portable hard drive all day. We will show people how to restore the SSD to working order.
The hard drive could be replaced with any SATA hard drive with 2.5" wide, 7m high.
Before starting, you need to disconnect all power sources while operating and must follow the guide to disable the built-in battery.
Back up your hard drive is highly recommended before replace.
Wat je nodig hebt
To reassemble your device, follow these instructions in reverse order. Remember to push back the lid on the SATA connector.
