Ga door naar hoofdinhoud
Lenovo ThinkPad Edge E420s Hard Drive Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad Edge E420s Hard Drive Replacement, Hard Drive: stap 1, afbeelding 1 van 1
    • There is no external access to the battery. Please make sure the at the battery has been drained or disabled through BIOS before beginning.
    • Flip the device over.
  2. Lenovo ThinkPad Edge E420s Hard Drive Replacement: stap 2, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove one M2 x 3mm screw from the side of the device.
  3. Lenovo ThinkPad Edge E420s Hard Drive Replacement: stap 3, afbeelding 1 van 3 Lenovo ThinkPad Edge E420s Hard Drive Replacement: stap 3, afbeelding 2 van 3 Lenovo ThinkPad Edge E420s Hard Drive Replacement: stap 3, afbeelding 3 van 3
    • Swing the cover out slightly like a hinge.
    • Pull the cover directly away from the case towards the base of the laptop.
    • Lift the cover up and away from the device to remove it.
    • You may hear a slight pop when you pull the cover off.
  4. Lenovo ThinkPad Edge E420s Hard Drive Replacement: stap 4, afbeelding 1 van 1
    • Use the clear tab to slide the hard drive out of the device.
  5. Lenovo ThinkPad Edge E420s Hard Drive Replacement: stap 5, afbeelding 1 van 3 Lenovo ThinkPad Edge E420s Hard Drive Replacement: stap 5, afbeelding 2 van 3 Lenovo ThinkPad Edge E420s Hard Drive Replacement: stap 5, afbeelding 3 van 3
    • To replace the hard drive, remove the four M2 × 4mm wafer-headed screws on the sides of the hard drive case using a Phillips #00 screwdriver.
    • Slide the old hard drive directly out.
    • When reassembling, make sure the hard drive is securely in the case before beginning.
Conclusie
4 andere personen hebben deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 63
Altijd: 2,804
