Ga door naar hoofdinhoud
Lenovo ThinkPad Edge E420s Glass Screen Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad Edge E420s Glass Screen Replacement, Hard Drive: stap 1, afbeelding 1 van 1
    • There is no external access to the battery. Please make sure the at the battery has been drained or disabled through BIOS before beginning.
    • Flip the device over.
  2. Lenovo ThinkPad Edge E420s Glass Screen Replacement: stap 2, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove one M2 x 3mm screw from the side of the device.
  3. Lenovo ThinkPad Edge E420s Glass Screen Replacement: stap 3, afbeelding 1 van 3 Lenovo ThinkPad Edge E420s Glass Screen Replacement: stap 3, afbeelding 2 van 3 Lenovo ThinkPad Edge E420s Glass Screen Replacement: stap 3, afbeelding 3 van 3
    • Swing the cover out slightly like a hinge.
    • Pull the cover directly away from the case towards the base of the laptop.
    • Lift the cover up and away from the device to remove it.
    • You may hear a slight pop when you pull the cover off.
  4. Lenovo ThinkPad Edge E420s Glass Screen Replacement: stap 4, afbeelding 1 van 1
    • Use the clear tab to slide the hard drive out of the device.
  5. Lenovo ThinkPad Edge E420s Glass Screen Replacement: stap 5, afbeelding 1 van 3 Lenovo ThinkPad Edge E420s Glass Screen Replacement: stap 5, afbeelding 2 van 3 Lenovo ThinkPad Edge E420s Glass Screen Replacement: stap 5, afbeelding 3 van 3
    • To replace the hard drive, remove the four M2 × 4mm wafer-headed screws on the sides of the hard drive case using a Phillips #00 screwdriver.
    • Slide the old hard drive directly out.
    • When reassembling, make sure the hard drive is securely in the case before beginning.
  6. Lenovo ThinkPad Edge E420s Glass Screen Replacement, Top Case: stap 6, afbeelding 1 van 2 Lenovo ThinkPad Edge E420s Glass Screen Replacement, Top Case: stap 6, afbeelding 2 van 2
    • Use a Phillips #0 screwdriver to remove eight M2 × 3 mm screws near the front opening and scattered across the bottom of the laptop.
    • Remove three M2x3 mm screws using a Phillips #00 screwdriver from the base of the laptop near the opening.
  7. Lenovo ThinkPad Edge E420s Glass Screen Replacement: stap 7, afbeelding 1 van 1
    • Remove the M3 x 2mm screw from the hole left by the hard drive using a Phillips #00 screwdriver.
  8. Lenovo ThinkPad Edge E420s Glass Screen Replacement: stap 8, afbeelding 1 van 2 Lenovo ThinkPad Edge E420s Glass Screen Replacement: stap 8, afbeelding 2 van 2
    • Flip over the device.
    • Open the device normally.
  9. Lenovo ThinkPad Edge E420s Glass Screen Replacement: stap 9, afbeelding 1 van 1
    • Wedge the plastic opening tool between the upper and lower halves of the lower case.
    • Lift the end of the opening tool slowly until the case separates.
    • Hearing a small popping or cracking noise during this step is normal
  10. Lenovo ThinkPad Edge E420s Glass Screen Replacement: stap 10, afbeelding 1 van 1
    • Lift the upper half of the case up slowly.
    • Be sure not to yank any of the wires connected to the case as this could damage them.
  11. Lenovo ThinkPad Edge E420s Glass Screen Replacement: stap 11, afbeelding 1 van 3 Lenovo ThinkPad Edge E420s Glass Screen Replacement: stap 11, afbeelding 2 van 3 Lenovo ThinkPad Edge E420s Glass Screen Replacement: stap 11, afbeelding 3 van 3
    • Locate and disconnect the 4 ribbon wires from the top case.
    • Locate and disconnect the two additional connecting wires.
    • Some wires may be connected by a clamp. In order to remove the clamp, press upwards on the lever attached to the connector
    • Be careful to not yank on the wires when disconnecting them as they are easily damaged.
  12. Lenovo ThinkPad Edge E420s Glass Screen Replacement: stap 12, afbeelding 1 van 1
    • Lift the unattached case away from the device and place it to the side.
    • When reassembling ensure that all parts of the case are properly aligned.
  13. Lenovo ThinkPad Edge E420s Glass Screen Replacement, Glass Screen: stap 13, afbeelding 1 van 2 Lenovo ThinkPad Edge E420s Glass Screen Replacement, Glass Screen: stap 13, afbeelding 2 van 2
    • Unscrew the two M2 x 3mm screws near the hinges using a Phillips #00 screwdriver.
  14. Lenovo ThinkPad Edge E420s Glass Screen Replacement: stap 14, afbeelding 1 van 3 Lenovo ThinkPad Edge E420s Glass Screen Replacement: stap 14, afbeelding 2 van 3 Lenovo ThinkPad Edge E420s Glass Screen Replacement: stap 14, afbeelding 3 van 3
    • Slide the black and grey wires out from underneath the plastic tab with the plastic opening tool.
    • Disconnect the black and grey wires connecting the screen and the motherboard.
  15. Lenovo ThinkPad Edge E420s Glass Screen Replacement: stap 15, afbeelding 1 van 1
    • Pull out the fabric covered wire connecting the Screen to the motherboard underneath the cooling fan.
    • Make sure to pull parallel to the slot the wire is connected to, otherwise you may damage or completely break it.
  16. Lenovo ThinkPad Edge E420s Glass Screen Replacement: stap 16, afbeelding 1 van 1
    • Lift the screen away from the device.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 8
Altijd: 555
