Inleiding
If your laptop is unable to connect to the Internet, can't find Bluetooth devices, or has poor Wi-Fi Connection no matter what network you use, your Wi-Fi Card may be the issue. Follow this guide in order to learn how to properly and safely replace your laptops Wi-Fi Card.
Wi-Fi Card's tend to go bad due to general damage and overheating, with prolonged heat either from poor cooling or prolonged use in hot environments potentially causing the Wi-Fi Card to randomly fail, or stop working all together. However most Wi-Fi Cards do not degrade due to age, and will only begin failing due to damage.
Before using this guide, ensure that the issue is with the Wi-Fi card. While replacing the Wi-Fi card is inexpensive, it is worth checking before if the issue is the Wi-Fi Drivers on the laptop being outdated or corrupted. Additionally it is worth trying the methods found within Wi-Fi Not Working Correctly, to properly diagnose the issue.
This guide requires opening the laptop case and exposing internal components. Be cautious of sharp edges and avoid touching any circuitry and exposed electronics to prevent damage from static electricity. Use an anti-static wrist strap (such as one of these) if possible, and make sure your laptop is completely powered off and unplugged before beginning the replacement process.
Wat je nodig hebt
Gereedschap gebruikt in deze stap:Phillips #1 Screwdriver$5.49
Loosen the eight PH1 screws on the back panel using the Phillips #1 screwdriver.
Gereedschap gebruikt in deze stap:iFixit Opening Tool$1.99
Remove back panel using a plastic opening tool or a spudger.
Slide a thin, ESD-safe pry tool or angled tweezers under the metal neck of the connector (as close to the head as possible) and lift straight up from the board.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
