Inleiding
In this guide, you will learn how to properly access each of the speakers within the Lenovo Tab S8 and remove them safely.
Wat je nodig hebt
Gently insert a spudger into one of the bottom corners between the screen and body case.
Slide the spudger along the inside of the crack in order to pry the case open.
Gereedschap gebruikt in deze stap:Plastic Cards$2.99
Gently lift the flaps on the four ZIF connectors to disconnect the cables.
Use the plastic card to gently pry the battery from the device.
Use the tip of a spudger or your fingernail to flip up the small locking flap. Then, you can safely pull the cable out from under the camera.
Once you have removed the motherboard and the battery, locate both the upper and lower speakers.
Lift up the wire with a plastic opening tool. Make sure this tool has a sharp edge.
