Wat je nodig hebt
Gently insert a spudger into one of the bottom corners between the screen and body case.
Slide the spudger along the inside of the crack in order to pry the case open.
Gereedschap gebruikt in deze stap:Plastic Cards$2.99
Gently lift the flaps on the four ZIF connectors to disconnect the cables.
Use the plastic card to gently pry the battery from the device.
Use the tip of a spudger or your fingernail to flip up the small locking flap. Then, you can safely pull the cable out from under the camera.
6 andere personen hebben deze handleiding voltooid.
Bought a battery connector gets hot and doesn't turn on
James Rego - Antwoord
