Inleiding
This guide will show you how to safely remove the battery component of your tablet.
Wat je nodig hebt
Place the tablet face down on a soft, stable surface that will protect the screen.
Next, Scrape off the seal over the screw in the back of the tablet with a Metal Spudger.
Use the Phillips #000 Screwdriver to remove the M1.4 × 2.5 screw.
Using a counterclockwise motion with the Phillips #000 screwdriver, remove the M1.4 × 2.5 screw that holds down the copper strip connected to the battery.
With a pair of Tweezers, carefully unplug the strip connecting the battery to the motherboard.
5 andere personen hebben deze handleiding voltooid.
2 opmerkingen
I fixit might have a replacement battery
