Inleiding
This guide will provide step by step instructions on how to replace the battery in your Lenovo Tab 2 A7-20F.
Note: Before removing the battery, make sure that the device is shut down completely and that the charger is disconnected. Make sure that your hands are dry and that you have discharged any built up static charge by touching a good ground source. This will help to avoid damaging any electric components.
Wat je nodig hebt
Starting at any point along the seam of the case carefully pry it open with the metal spudger, slowly working your way around the outside until the case can come apart.
