Ga door naar hoofdinhoud
Lenovo Tab 2 A10-70 Rear Facing Camera Replacement
Wat je nodig hebt
  1. Lenovo Tab 2 A10-70 Rear Facing Camera  Replacement, Rear Facing Camera: stap 1, afbeelding 1 van 1
    • Before removing the camera, make sure the device is powered off
    • Use a plastic opening tool to pry open the back cover of the tablet..
  2. Lenovo Tab 2 A10-70 Rear Facing Camera  Replacement: stap 2, afbeelding 1 van 1
    • Locate the cable that is connecting the camera to the tablet
  3. Lenovo Tab 2 A10-70 Rear Facing Camera  Replacement: stap 3, afbeelding 1 van 1
    • Disconnect the cable that is connecting the camera to the tablet
  4. Lenovo Tab 2 A10-70 Rear Facing Camera  Replacement: stap 4, afbeelding 1 van 2 Lenovo Tab 2 A10-70 Rear Facing Camera  Replacement: stap 4, afbeelding 2 van 2
    • Simply remove the camera from the tablet by lifting it up
    • Repeat Steps in reverse order with a new camera for reassembly
Conclusie
Tyler Hagenlocher
350 Reputatie
2 handleidingen geschreven
USF Tampa, Team 12-6, Eyestone Spring 2016 Lid van USF Tampa, Team 12-6, Eyestone Spring 2016
USFT-EYESTONE-S16S12G6
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 10
Altijd: 903
