Inleiding
The motherboard controls all of the processes of the device and if it is faulty must be replaced otherwise the device will not operate.
Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Use a plastic opening tool to pry open the back cover of the tablet.
The second picture shows the tablet with the back removed.
Remove the following screws using the Phillips #000 screwdriver.
Eleven 4 mm screws in total.
6 andere personen hebben deze handleiding voltooid.
5 Opmerkingen
My daughter's tablet is jumping flashing glitching and showing vertical lines it just started happening out of the blue what can I do to fix it.
Is anybody knows what that black tape thing in the video?
https://youtu.be/etxKSTK3Gno?t=8m19s
Thank you!
That’s probably, the wifi antenna/booster….
voneout -
this tablet does not support any android update anymore and has historical issues with wifi. Can any newer motherboard be installed with the same screen and battery and case? some sort of HW upgrade last trial before it ends in the bin...
