Ga door naar hoofdinhoud
Lenovo S20-30 Keyboard Replacement
Wat je nodig hebt
  1. Lenovo S20-30 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Flip the Lenovo S20-30 over so that the bottom panel is facing upward.
  2. Lenovo S20-30 Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Slide the manual battery latch to the unlock position, so that the red is showing.
  3. Lenovo S20-30 Keyboard Replacement: stap 3, afbeelding 1 van 2 Lenovo S20-30 Keyboard Replacement: stap 3, afbeelding 2 van 2
    • Slide and hold the spring-loaded battery latch on the other side (right) while sliding the battery out of the computer.
    • Grab new Lenovo S20-30 battery for replacement.
  4. Lenovo S20-30 Keyboard Replacement, Keyboard: stap 4, afbeelding 1 van 3 Lenovo S20-30 Keyboard Replacement, Keyboard: stap 4, afbeelding 2 van 3 Lenovo S20-30 Keyboard Replacement, Keyboard: stap 4, afbeelding 3 van 3
    • Remove the two front rubber feet using a long metal spudger.
    • Use your Phillips #0 screwdriver to remove the two M2.5 x 5mm flat-head screws located underneath the pads.
  5. Lenovo S20-30 Keyboard Replacement: stap 5, afbeelding 1 van 1
    • Use the Phillips #0 screwdriver to remove the nine M2 x 4mm flat head screws located on the outer edges on the back of the laptop.
    • Make sure to keep these screws separated from future screws that will be disassembled throughout this process.
  6. Lenovo S20-30 Keyboard Replacement: stap 6, afbeelding 1 van 2 Lenovo S20-30 Keyboard Replacement: stap 6, afbeelding 2 van 2
    • Use the long metal spudger to pry open the bottom half of the laptop.
    • Gently lift the cover off to reveal the motherboard.
  7. Lenovo S20-30 Keyboard Replacement: stap 7, afbeelding 1 van 2 Lenovo S20-30 Keyboard Replacement: stap 7, afbeelding 2 van 2
    • Remove the four M2 x 3mm flat-head screw using a Phillips #000 screwdriver.
  8. Lenovo S20-30 Keyboard Replacement: stap 8, afbeelding 1 van 2 Lenovo S20-30 Keyboard Replacement: stap 8, afbeelding 2 van 2
    • Flip over laptop and open the lid to have access to the keyboard.
    • Use a plastic opening tool to pry apart the keyboard.
  9. Lenovo S20-30 Keyboard Replacement: stap 9, afbeelding 1 van 3 Lenovo S20-30 Keyboard Replacement: stap 9, afbeelding 2 van 3 Lenovo S20-30 Keyboard Replacement: stap 9, afbeelding 3 van 3
    • A connector is attached to the keyboard.
    • Remove it by gently pulling it outward.
  10. Lenovo S20-30 Keyboard Replacement: stap 10, afbeelding 1 van 1
    • Grab replacement keyboard to insert back into place.
Conclusie
3 andere personen hebben deze handleiding voltooid.
ILEANISSE SOTO
187 Reputatie
1 Handleiding geschreven
Één opmerking
where can i find a replacement keyboard/ or what model # do i need?
ed paz - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 13
Altijd: 1,217
