Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Video overzicht
Deze stap is niet vertaald. Help het te vertalen
Flip the Lenovo S20-30 over so that the bottom panel is facing upward.
Slide the manual battery latch to the unlock position, so that the red is showing.
Slide and hold the spring-loaded battery latch on the other side (right) while sliding the battery out of the computer.
Grab new Lenovo S20-30 battery for replacement.
Pry open the frame using a plastic opening tool.
Pull frame upward to remove it.
Unscrew four M2 x 3mm screws using a Phillips #000 screwdriver.
Slowly remove display monitor to reveal the connector.
Remove the connector by gently pulling it out.
