Ga door naar hoofdinhoud
Lenovo N22 Chromebook Keyboard Replacement
Wat je nodig hebt
  1. Lenovo N22 Chromebook Keyboard Replacement, Keyboard: stap 1, afbeelding 1 van 3 Lenovo N22 Chromebook Keyboard Replacement, Keyboard: stap 1, afbeelding 2 van 3 Lenovo N22 Chromebook Keyboard Replacement, Keyboard: stap 1, afbeelding 3 van 3
    • Power down the Chromebook before starting the repair.
    • Opening the Chromebook voids the manufacturer warranty.
    • Flip the Chromebook so that the bottom is facing up.
    • Use a Phillips #1 screwdriver to remove the six 6.6 mm screws on the bottom.
    • Use a spudger to remove each of the 4 rubber feet.
    • Use a Phillips #1 screwdriver to remove the four additional screws under the rubber feet.
  2. Lenovo N22 Chromebook Keyboard Replacement: stap 2, afbeelding 1 van 3 Lenovo N22 Chromebook Keyboard Replacement: stap 2, afbeelding 2 van 3 Lenovo N22 Chromebook Keyboard Replacement: stap 2, afbeelding 3 van 3
    • Flip the Chromebook back over and open the screen.
    • Wedge the plastic opening tool between the keyboard and the bottom of the Chromebook.
    • Run the plastic opening tool along the seam between the keyboard and the bottom of the Chromebook until the keyboard moves freely. Several tabs will pop out.
    • It is normal for the tabs to make a loud click when released. The corner tabs will be harder to release than the others and will make a louder click.
  3. Lenovo N22 Chromebook Keyboard Replacement: stap 3, afbeelding 1 van 2 Lenovo N22 Chromebook Keyboard Replacement: stap 3, afbeelding 2 van 2
    • Once the keyboard is released, grab the two top corners closest to the screen and slowly lift the keyboard up.
    • Do not lift the keyboard quickly or you might break the two cables that connect the keyboard to the motherboard.
    • Disconnect the cables by lifting up the retaining flaps on the black ZIF connectors.
    • Slowly pull the cables up and out of the connectors.
  4. Lenovo N22 Chromebook Keyboard Replacement: stap 4, afbeelding 1 van 1
    • Lift the keyboard up and off the back panel, exposing the motherboard and battery.
Conclusie
8 andere personen hebben deze handleiding voltooid.
Jackson Tucker
869 Reputatie
3 handleidingen geschreven
Cal Poly, Team S21-G1, Livingston Spring 2017 Lid van Cal Poly, Team S21-G1, Livingston Spring 2017
CPSU-LIVINGSTON-S17S21G1
4 Leden
14 handleidingen geschreven
6Gids Commentaar
I have this laptop. The top right corner of the keyboard has popped out. How do I fix this?
Michael Faherty - Antwoord
Try removing the rubber foot under the popped corner, remove the screw, push down on the corner and replace the screw while holding the corner down.
Craig Carlson -
Just a note: the little rubber feet are all lettered (A-D) and you do need to match them to their proper corners when re-assembling.
Craig Carlson -
I have several keys that have stopped working. Replace the keyboard or is there a fix?
Richard Williams - Antwoord
This happen when the ribbon cable that connects the keyboard gets squashed too hard.
See [1] below for a decription and fix.
[1] https://forums.lenovo.com/t5/Lenovo-Chro...
Jan -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 41
Altijd: 14,144
