Ga door naar hoofdinhoud
Lenovo N20p Chromebook Battery Replacement
Wat je nodig hebt
  1. Lenovo N20p Chromebook Battery Replacement, Keyboard: stap 1, afbeelding 1 van 2 Lenovo N20p Chromebook Battery Replacement, Keyboard: stap 1, afbeelding 2 van 2
    • Power down the Chromebook before starting any repair.
    • Remove the two 3.5 mm Phillips #0 screws using a screwdriver.
    • It is only necessary to remove these two screws to complete this step.
  2. Lenovo N20p Chromebook Battery Replacement: stap 2, afbeelding 1 van 2 Lenovo N20p Chromebook Battery Replacement: stap 2, afbeelding 2 van 2
    • Use the hook of the metal spudger to carefully lift up the keyboard.
    • Lift the keyboard carefully. If you lift too quickly, it might break the two cables that connect the keyboard to the motherboard.
  3. Lenovo N20p Chromebook Battery Replacement: stap 3, afbeelding 1 van 3 Lenovo N20p Chromebook Battery Replacement: stap 3, afbeelding 2 van 3 Lenovo N20p Chromebook Battery Replacement: stap 3, afbeelding 3 van 3
    • Carefully, disconnect the keyboard cable from the motherboard carefully by pulling on the blue tab of the cable.
    • You will now be able to replace the keyboard.
  4. Lenovo N20p Chromebook Battery Replacement, Battery: stap 4, afbeelding 1 van 3 Lenovo N20p Chromebook Battery Replacement, Battery: stap 4, afbeelding 2 van 3 Lenovo N20p Chromebook Battery Replacement, Battery: stap 4, afbeelding 3 van 3
    • Remove the two rubber feet of the back of the Chromebook using a metal spudger.
    • Remove six bottom 3.5 mm Phillips #0 screws and two top 5 mm Phillips #1 screws.
  5. Lenovo N20p Chromebook Battery Replacement: stap 5, afbeelding 1 van 1
    • Remove all nine 3.5 mm Phillips #00 screws using a screwdriver.
  6. Lenovo N20p Chromebook Battery Replacement: stap 6, afbeelding 1 van 2 Lenovo N20p Chromebook Battery Replacement: stap 6, afbeelding 2 van 2
    • Disconnect the battery cable from the motherboard.
    • Disconnect the touch-pad cable from the motherboard.
  7. Lenovo N20p Chromebook Battery Replacement: stap 7, afbeelding 1 van 2 Lenovo N20p Chromebook Battery Replacement: stap 7, afbeelding 2 van 2
    • Use the metal spudger along the seam between the keyboard and the bottom of the Chromebook to lift up and remove the palm rest assembly.
    • It is normal for it to click loudly when it is released. Corner tags will be harder to release than other tags and will make a loud sound.
  8. Lenovo N20p Chromebook Battery Replacement: stap 8, afbeelding 1 van 3 Lenovo N20p Chromebook Battery Replacement: stap 8, afbeelding 2 van 3 Lenovo N20p Chromebook Battery Replacement: stap 8, afbeelding 3 van 3
    • Disconnect the USB cable from the motherboard by pulling the blue tab out of the cable.
    • Remove all five 3.0 mm Phillips #00 screws which connect the battery and motherboard.
  9. Lenovo N20p Chromebook Battery Replacement: stap 9, afbeelding 1 van 2 Lenovo N20p Chromebook Battery Replacement: stap 9, afbeelding 2 van 2
    • Remove the battery.
    • It is helpful to lift and hold the battery as shown.
Conclusie
Shihao Cao
497 Reputatie
4 handleidingen geschreven
UW Tacoma, Team S1-G2, Cardinal Summer 2018 Lid van UW Tacoma, Team S1-G2, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G2
3 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 7
Altijd: 446
