Ga door naar hoofdinhoud
Inleiding
Learn how to remove the speakers from the Miix 2 in a few, quick steps.
  1. Remove the back cover of the tablet by inserting a nylon or metal spudger in the small hole between the screen and rear cover near the volume button. Slide the tool along the edge of the tablet to release the internal clasps. You should have to apply a good amount of force, but pry carefully in order to avoid damaging the clasps or the internals.
    • Remove the back cover of the tablet by inserting a nylon or metal spudger in the small hole between the screen and rear cover near the volume button. Slide the tool along the edge of the tablet to release the internal clasps.
    • You should have to apply a good amount of force, but pry carefully in order to avoid damaging the clasps or the internals.
  2. Unscrew the six 3mm screws surrounding the battery dock using a Phillips #0 screwdriver. Unscrew the six 3mm screws surrounding the battery dock using a Phillips #0 screwdriver.
    • Unscrew the six 3mm screws surrounding the battery dock using a Phillips #0 screwdriver.
  3. Using a plastic spudger, slowly push each side of the battery connector (back and forward a couple of times) out of its socket on the motherboard. Using a plastic spudger, slowly push each side of the battery connector (back and forward a couple of times) out of its socket on the motherboard.
    • Using a plastic spudger, slowly push each side of the battery connector (back and forward a couple of times) out of its socket on the motherboard.
  4. Remove the battery by prying up with your fingers or a plastic opening tool. Remove the battery by prying up with your fingers or a plastic opening tool.
    • Remove the battery by prying up with your fingers or a plastic opening tool.
  5. Remove the red and black connector cable linking the speakers to the motherboard with tweezers by pulling the connector to the left with a light degree of force. To properly remove the speakers from the casing, push gently left until it shifts, then pull directly up.
    • Remove the red and black connector cable linking the speakers to the motherboard with tweezers by pulling the connector to the left with a light degree of force.
    • To properly remove the speakers from the casing, push gently left until it shifts, then pull directly up.
Conclusie
Diana Chiu
654 Reputatie
4 handleidingen geschreven
Kid fixers Lid van Kid fixers
Community
117 Leden
79 handleidingen geschreven
0 Opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 870
