Ga door naar hoofdinhoud
Lenovo Miix 2 External Buttons on Back Cover Replacement
Wat je nodig hebt
  1. Lenovo Miix 2 External Buttons on Back Cover Replacement, External Buttons on Back Cover: stap 1, afbeelding 1 van 1
    • Gently insert metal spudger into back panel of the device.
    • Remove the back cover with your hand.
  2. Lenovo Miix 2 External Buttons on Back Cover Replacement: stap 2, afbeelding 1 van 3 Lenovo Miix 2 External Buttons on Back Cover Replacement: stap 2, afbeelding 2 van 3 Lenovo Miix 2 External Buttons on Back Cover Replacement: stap 2, afbeelding 3 van 3
    • Using the tweezers remove the volume button located towards the top of the device, near the rear camera cut out.
    • Next, gently lift up on the power button, once again using the tweezers, which is located above the volume button along the same side of the device.
Conclusie
Max Rozema
157 Reputatie
2 handleidingen geschreven
IUPUI, Team S3-G1, Harley Spring 2019 Lid van IUPUI, Team S3-G1, Harley Spring 2019
IUPUI-HARLEY-S19S3G1
3 Leden
Één opmerking
pleas i need the Lenovo Miix 2 External Buttons on Back Cover how to find it it's has part nomber help me pls.
Ahmed Almaiman - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 12
Altijd: 339
