Ga door naar hoofdinhoud
Lenovo Legion Y530-15ICH USB Port Replacement
Wat je nodig hebt
  1. Lenovo Legion Y530-15ICH USB Port Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Ensure the device is powered off.
    • Use a PZ00 screwdriver bit to remove the eleven screws securing the back cover.
    • Five 7 mm screws
    • Six 4 mm screws
  2. Lenovo Legion Y530-15ICH USB Port Replacement: stap 2, afbeelding 1 van 2 Lenovo Legion Y530-15ICH USB Port Replacement: stap 2, afbeelding 2 van 2
    • Carefully pry the back cover off the computer using an opening pick.
    • Start at the corner of the laptop and work your way around the side. Gently pull up on the cover until it detaches.
  3. Lenovo Legion Y530-15ICH USB Port Replacement, USB Port: stap 3, afbeelding 1 van 2 Lenovo Legion Y530-15ICH USB Port Replacement, USB Port: stap 3, afbeelding 2 van 2
    • Remove the ribbon cable connecting the USB port to the motherboard, located adjacent to the fan unit.
    • Using a JIS #1 screwdriver, remove the two screws securing the USB port to the module.
  4. Lenovo Legion Y530-15ICH USB Port Replacement: stap 4, afbeelding 1 van 1
    • Gently disconnect the single ribbon cable with your fingers.
    • Remove the USB port from the device.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 19
Altijd: 993
