Ga door naar hoofdinhoud
Lenovo Legion Y520-15IKBN Wi-Fi Card Replacement
Wat je nodig hebt
  1. Lenovo Legion Y520-15IKBN Wi-Fi Card Replacement, Base Panel: stap 1, afbeelding 1 van 2 Lenovo Legion Y520-15IKBN Wi-Fi Card Replacement, Base Panel: stap 1, afbeelding 2 van 2
    • Shut down and unplug your device before proceeding.
    • Remove the thirteen 6.5 mm screws from the base plate using a Phillips #00 screwdriver.
  2. Lenovo Legion Y520-15IKBN Wi-Fi Card Replacement: stap 2, afbeelding 1 van 1
    • Flip the laptop on its side and wedge a spudger between the base panel and chassis, then pry around the perimeter until the base panel releases.
    • To get a better grip you may want to open the laptop slightly.
    • Lift the bottom panel off of the chassis.
    • During reassembly, make sure that the bottom panel clicks back into place on all four sides of the laptop.
  3. Lenovo Legion Y520-15IKBN Wi-Fi Card Replacement, Wi-Fi  Card: stap 3, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove the single screw securing the Wi-Fi card.
  4. Lenovo Legion Y520-15IKBN Wi-Fi Card Replacement: stap 4, afbeelding 1 van 1
    • Pull the Wi-Fi card directly out of its port.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 27
Altijd: 503
