Inleiding
This guide will show you how to properly replace the keycaps on your keyboard. The keycaps may need to be replaced on your keyboard if they are sticky, broken or don't properly register to your device.
Wat je nodig hebt
Carefully remove the broken key(s). Use the flat end of the spudger to gently pop the key off.
3 opmerkingen
This is only for the key caps, what about the keyboard itself?
I agree the video is mislabeled. You are not replacing the board just keys.
