Ga door naar hoofdinhoud
Lenovo Legion Y520-15IKBN Keyboard Keycap Replacement
Wat je nodig hebt
  1. Lenovo Legion Y520-15IKBN Keyboard Keycap Replacement, Keyboard Keycap: stap 1, afbeelding 1 van 3 Lenovo Legion Y520-15IKBN Keyboard Keycap Replacement, Keyboard Keycap: stap 1, afbeelding 2 van 3 Lenovo Legion Y520-15IKBN Keyboard Keycap Replacement, Keyboard Keycap: stap 1, afbeelding 3 van 3
    • Carefully remove the broken key(s). Use the flat end of the spudger to gently pop the key off.
    • When removing the key(s) be very cautious not to remove the white plastic pieces underneath with it.
    • When reinstalling key, no spudger is needed. Just pop it into place with fingers.
  2. Lenovo Legion Y520-15IKBN Keyboard Keycap Replacement: stap 2, afbeelding 1 van 2 Lenovo Legion Y520-15IKBN Keyboard Keycap Replacement: stap 2, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Using the flat end of the spudger, very carefully lift up the corners of the white plastic piece. Do not disconnect the two.
    • With the help of tweezers (needle nose works best), pull the connected plastic pieces out.
    • If the two plastic pieces come apart refer to the last picture, showing the orientation in which they should be connected.
    • For reinstallation of the plastic piece use tweezers to put it back in place and pop the bottom half in before the top.
Conclusie
Kaylea
185 Reputatie
1 Handleiding geschreven
3 opmerkingen
This is only for the key caps, what about the keyboard itself?
Rick Montoya - Antwoord
I agree the video is mislabeled. You are not replacing the board just keys.
Pat Schutte - Antwoord
Please create a tutorial for keys with stabilizer like space bar and enter keys.
Affix - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 23
Afgelopen 30 dagen: 143
Altijd: 10,411
