Inleiding
This guide will walk you through the steps on how to replace your Levono Legion y520 fan. In cases when your fan maybe overheating or not working you will need this guide. NOTE: There are a lot of wires. Be sure to keep track of where each one goes.
Wat je nodig hebt
Remove the thirteen 6.5 mm screws from the base plate using a Phillips #00 screwdriver.
Unplug the battery then, you will need to remove the four 4 mm screws around the fan using a Phillips #00 screwdriver.
9 andere personen hebben deze handleiding voltooid.
