Inleiding
Luckily for repairers, pulling the battery out of the Lenovo K5 Note is a simple task. Unfortunately, however, a broken display will require a bit of work for repair, thus yielding a repairability score of 6 out of 10.
Onderdelen
Geen onderdelen nodig.
The primary camera is firmly glued to the midframe. It might be possible to extract it without first removing the motherboard, but only with some risk of pry damage to the motherboard.
The selfie camera is installed on the back of the motherboard, requiring removal of the motherboard for access.
Both cameras are modular.
With the interconnect cables out, this is as far as we go. The display looks to be firmly secured to a mid-frame for rigidity and would be impractical to separate. While it's the most likely component to break, everything else mounts to it—making it effectively the last component to be removed.
The Lenovo K5 Note earns a 6 out of 10 on our repairability scale (10 is the easiest to repair):
Battery is replaceable with just a couple of tools.
A single Phillips 00 driver takes care of all the screws.
Some parts are modular, but high-wear components like the headphone jack and charge port are not.
Sparing use of adhesive.
Replacing the display assembly requires removing every other component from the device first.
Manufacturer does not provide user-accessible repair documentation.
26 andere personen hebben deze handleiding voltooid.
5 Opmerkingen
I repaired (assembled)my old phone and the useful parts are sold (which is in dead mobile
Bro...My phone wifi not connecting
Error.plug out the charger
How to fix this problem in k5 note
My phone is not working from yesterday, its getting heated up , so i follow the tutorial and remove the battery jack , and whenever i am connecting the battery jack it is heating up again , am really scared to connect the jack back, what could be the possible reason for it to get heated up so badly , i am blindly guessing there is some short circuit , please help me to go through it.
