Ga door naar hoofdinhoud
Lenovo Ideatab A1107 Screen Replacement
Wat je nodig hebt
  1. Lenovo Ideatab A1107 Screen Replacement, Back Cover: stap 1, afbeelding 1 van 2 Lenovo Ideatab A1107 Screen Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Insert a plastic opener in-between the black back panel and the silver body of the tablet.
    • Use the plastic opener to pry the back panel off by moving the plastic opener around the outside edge of the device.
  2. Lenovo Ideatab A1107 Screen Replacement: stap 2, afbeelding 1 van 2 Lenovo Ideatab A1107 Screen Replacement: stap 2, afbeelding 2 van 2
    • Use a Phillips #000 screwdriver to remove the seventeen 4mm screws.
  3. Lenovo Ideatab A1107 Screen Replacement: stap 3, afbeelding 1 van 1
    • Lift up and remove the interior casing to expose the inner components.
    • Do not be alarmed if the volume button and lock button fall off when removing the interior casing.
  4. Lenovo Ideatab A1107 Screen Replacement, Battery: stap 4, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Use tweezers to remove the tape covering the battery's wiring.
  5. Lenovo Ideatab A1107 Screen Replacement: stap 5, afbeelding 1 van 2 Lenovo Ideatab A1107 Screen Replacement: stap 5, afbeelding 2 van 2
    • Do not puncture the lithium-ion battery. Ruptured batteries can catch fire or explode.
    • Do not use metal tools to remove the battery wire. They present the risk of electrocution.
    • Use a plastic spudger tool to push the battery's wire harness and disconnect it from the device.
  6. Lenovo Ideatab A1107 Screen Replacement: stap 6, afbeelding 1 van 1
    • Wedge a plastic opening tool in between the battery and the internal components of the device.
    • Use the plastic opener tool to remove the battery from its casing.
  7. Lenovo Ideatab A1107 Screen Replacement, Screen: stap 7, afbeelding 1 van 1
    • Using you hands, lift off the digitizer.
  8. Lenovo Ideatab A1107 Screen Replacement: stap 8, afbeelding 1 van 2 Lenovo Ideatab A1107 Screen Replacement: stap 8, afbeelding 2 van 2
    • Remove the three screws that are 2.0 mm in length and have a 5.25 mm head width with a Phillips #00 screwdriver.
  9. Lenovo Ideatab A1107 Screen Replacement: stap 9, afbeelding 1 van 2 Lenovo Ideatab A1107 Screen Replacement: stap 9, afbeelding 2 van 2
    Koop
    • Use a spudger to remove the plastic piece securing the zero insertion force (ZIF) cable connector.
    • Use tweezers to grasp the ribbon cable, then pull the cable to disconnect it from the device.
  10. Lenovo Ideatab A1107 Screen Replacement: stap 10, afbeelding 1 van 1
    • Locate the black electrical tape strip on the side of the device.
    • Gently remove the tape from the device using the tweezers.
  11. Lenovo Ideatab A1107 Screen Replacement: stap 11, afbeelding 1 van 3 Lenovo Ideatab A1107 Screen Replacement: stap 11, afbeelding 2 van 3 Lenovo Ideatab A1107 Screen Replacement: stap 11, afbeelding 3 van 3
    • After removing the electric tape, gently lift up the green control panel.
    • Taking the tweezers, remove the ribbon cable from the control panel.
    • Once the ribbon cable is removed from the panel, the display should separate with ease.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 517
