Ga door naar hoofdinhoud
Lenovo Ideatab A1107 Battery Replacement
Wat je nodig hebt
  1. Lenovo Ideatab A1107 Battery Replacement, Back Cover: stap 1, afbeelding 1 van 2 Lenovo Ideatab A1107 Battery Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Insert a plastic opener in-between the black back panel and the silver body of the tablet.
    • Use the plastic opener to pry the back panel off by moving the plastic opener around the outside edge of the device.
  2. Lenovo Ideatab A1107 Battery Replacement: stap 2, afbeelding 1 van 2 Lenovo Ideatab A1107 Battery Replacement: stap 2, afbeelding 2 van 2
    • Use a Phillips #000 screwdriver to remove the seventeen 4mm screws.
  3. Lenovo Ideatab A1107 Battery Replacement: stap 3, afbeelding 1 van 1
    • Lift up and remove the interior casing to expose the inner components.
    • Do not be alarmed if the volume button and lock button fall off when removing the interior casing.
  4. Lenovo Ideatab A1107 Battery Replacement, Battery: stap 4, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Use tweezers to remove the tape covering the battery's wiring.
  5. Lenovo Ideatab A1107 Battery Replacement: stap 5, afbeelding 1 van 2 Lenovo Ideatab A1107 Battery Replacement: stap 5, afbeelding 2 van 2
    • Do not puncture the lithium-ion battery. Ruptured batteries can catch fire or explode.
    • Do not use metal tools to remove the battery wire. They present the risk of electrocution.
    • Use a plastic spudger tool to push the battery's wire harness and disconnect it from the device.
  6. Lenovo Ideatab A1107 Battery Replacement: stap 6, afbeelding 1 van 1
    • Wedge a plastic opening tool in between the battery and the internal components of the device.
    • Use the plastic opener tool to remove the battery from its casing.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 9
Altijd: 421
