Ga door naar hoofdinhoud
Lenovo Ideatab A1000 Wipe Data / Factory Reset (Hard Reset)
Wat je nodig hebt
Video overzicht
  1. Lenovo Ideatab A1000 Wipe Data / Factory Reset (Hard Reset), Lenovo Ideatab A1000 Wipe Data / Factory Reset (Hard Reset): stap 1, afbeelding 1 van 1
    • First of all you can try soft reset from the reset switch. This method does not delete the data from the tablet.
    how do you do a software reset?
    Z'Marion Perkins - Antwoord
  2. Lenovo Ideatab A1000 Wipe Data / Factory Reset (Hard Reset): stap 2, afbeelding 1 van 3 Lenovo Ideatab A1000 Wipe Data / Factory Reset (Hard Reset): stap 2, afbeelding 2 van 3 Lenovo Ideatab A1000 Wipe Data / Factory Reset (Hard Reset): stap 2, afbeelding 3 van 3
    • Now - hardware reset:
    • Switch off the tablet.
    • Press and hold at the same time Volume UP and Power keys.
    • When the System Recovery screen appears use the Volume Up/Down keys for navigation and the Power On key for OK.
    • Choose "wipe data / factory reset", "Yes -- delete all user data", "reboot system now".
    I need to download the file to reset in computer
    Khan MD Rehan - Antwoord
    How long it takes to reboot and In my tablet I clicked on reboot system now and a Lenovo logo was come and go off I don't know what was happening. I was waiting for 1 hours now tell me what would I need to do
    nitiksothiya5589 - Antwoord
    with me my tablet started to vibrate and then stopped after 5 minutes
    Fatibbs - Antwoord
    After hard reset its shows unfortunately key chain Has stopped and setting helper stopped again and again..
    Santhosh - Antwoord
    My system recovery screen goes off just as soon as I take my fingers off the two buttons, up and volume
    Martha Sigmon - Antwoord
    On my Lenovo tablet, my screen to reboot will not stay on for me to do a hard
    I'm doing everything like it said and when I keep press on the both bottoms and is not stay on to press ok for restat is going back to login
    mirelapitian2001 - Antwoord
    I’ve pressed quite long, and nothing happen. It doesnt work
    ́•„까́‹œSaRi - Antwoord
    I’ve had the same problem with my Lenovo Android.
    You have to keep holding power and up/down volume button to select. Release power button to select factory reset option.
    DJ Spy - Antwoord
    C’est fait mais j’arrive sur une fenĂªtre qui me demande de m’identifier avec mon compte Google. Je le fais mais sans rĂ©sultat
    Fernandes Mickael - Antwoord
  3. Lenovo Ideatab A1000 Wipe Data / Factory Reset (Hard Reset): stap 3, afbeelding 1 van 1
    • That's all.
    please will it keep long on the first step... when u press the volume up and power keys
    Belinda Daoussra - Antwoord
    That didn't work with my tablet
    After rebooting it asked for the language
    I entered English united states
    Then it shows just a sec and keeps on loading
    Albert jphn - Antwoord
    Indra Magar - Antwoord
Conclusie
47 andere personen hebben deze handleiding voltooid.
ZFix
191.278 Reputatie
330 handleidingen geschreven
Master Techs Lid van Master Techs
Community
322 Leden
2.528 handleidingen geschreven
36 opmerkingen
If device is connected to charger that button combination doesn't work. It goes to hardware test menu.
Pekka Lounatvuori - Antwoord
How to reser chinese language lenova phone
With Chinese phones, you do not need to use other options, and there is no confirmation. The wipe simply starts, and completes by wiping your phone. Read more - http://www.gogorapid.com/how-to-reset-ch...
Rumal Roma - Antwoord
My lenovo a 1000 idea tab's display is gone....no bottom in work...how to reset or fix it
ashiquehossain15 - Antwoord
my lenovo s850 is on meta mode when i press vol down + power button and nothing appear when i press vol up + power button.. the thing is i've tried many button sequence but i just cat get into reset mode or cynogen mode.. :(
wooblegooble92 - Antwoord
My lenovo tab isnt working until it went to some sort of menu using volume buttons but then i actually pressed something and it went to a screen saying "Now send the package you want to apply to the device using adb sideload <filename>" how do i go back to the reboot menu
Albert Einstein - Antwoord
i also tried same but i have not gotten any solution to mine too. what next please. i am missing my tab already
Afolabi Jonathan -
I'm getting information no SD card
ivan - Antwoord
sana gumana sa akin........
arielsatera - Antwoord
my lenovo tab 2 a7-30hc also has the problem. I did the same as what the video showed but it's still stuck on the lenovo logo. before the whole thing happened, my tablet was lagging so i thought about fixing it by uninstalling some apps until i pressed 'force stop' on an app. the battery got drained and the tab shut down. when i recharged it and attempted to turn it on, it was stuck on the logo. i waited for several minutes but its still the same. after that, i researched about how to fix it and i found this. I did it with my tab but nothing changed. it's still stuck. what should i do? the tab's not really mine. i just borrowed it from my father. if he finds out about what happened with his tablet, he might not talk to me for some time.. please answer me.
Razmia Lampak - Antwoord
How do I make my Lenovo tab pick up my wifi it's stopped and won't authenticate the password please help
Tracy - Antwoord
Please can someone help me my Lenovo won't authenticate my wifi password all of my other devices work fine it is the a7600 f
Tracy - Antwoord
My Lenovo tab shows encryption error and shows reset option,while the option isn't working..I tried for hard reset..that won't work too..and finally I tried to download new software..the tab isn't accepting it.
IS THERE ANY SOLUTION????
chaitanyajune29 - Antwoord
I reset my lenovo to factory reset then it asks for email that was previously sync to device. I type in email and password and it then goes back to asking me for email that was synced previously to device. And round and round it goes. How can i make tis work again.
robyntomlinson59@gmail.com
Robyn Tomlinson - Antwoord
Were you ever able to get it to login? Mine is doing the same thing
Brenda Carnell -
I am having the same sign in problem as Robyn with my Lenovo tablet
terri marble - Antwoord
Wich Chinese words do i push
mushieluv2 - Antwoord
my lenovo tab is showing nothing on the screen after factory reset
aditya rana - Antwoord
Did that now will kot go past lenovo screen saver?
asimon1926 - Antwoord
Done and I put in the wright email address and password then it keeps taking back there again keep going around in circles can you please help? Paulsculpher43@gmail.com
Paul - Antwoord
For anyone who may be having trouble with this fix please know that the volume up button is the button you use to select each line. So instead of hitting the power button when you have "wipe data/factory reset" highlighted press the volume up key to select and follow from there. Hope that change to the directions helps some of you.
irishemo13 - Antwoord
I used recovery mode to factory reset my tablet. After rebooting it asked for the language and I entered English united states then it shows just a sec
And keeps on loading
Can any one pl reply to my question above
loly of God so many
Sans the Killer bro - Antwoord
What should I do to my lenovo IdeatabA1000, always hang up if I watch YouTube and loading even I check my fb account. I can't download because its always say storage running out.. No games only fb,YouTube,messenger has been downloaded.. Pls. Help me
Mary Elly - Antwoord
After factory reset it says to go to the keyboard setting push the three dots and select update well mine doesn't have that option what do I do
Raylene - Antwoord
On my Lenovo tablet when I push the up and volume button at the same time, the page with the hard reset info won't stay on long enough for me to do a
When I hold up vol n power I only get recover, fastboot, normal. Tryed recover and still on normal screen asking for my pattern help please
reese Osborne - Antwoord
Thnk u For information.. im from indonesia
jason willy - Antwoord
Hi I have completed the factory reset then I went into Reboot system now but nothing happens my tablet is still stuck on the Lenevo logo and won't do anything . I have tried resetting several times also switchin off and restating but it still does not work !! Help ….
Cat Pellow - Antwoord
lenovo resate tab
M Younas - Antwoord
I have rooted my tablet and it won't start in recovery mode it just boot looped
Priya pari - Antwoord
I bought a lenovo tablet that is google locked and can't load my google account
chad1979.cw - Antwoord
after hard resat or wipe data lenovo tab not start atuck on lenovo logo. what to do help anyone.
Palmozone Enterprises - Antwoord
Nickel !
Je vais pouvoir me resservir de ma tablette !
Brigitte Tournie - Antwoord
RĂ©initialisation d'usine
venusbuttgousset - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 9
Afgelopen 7 dagen: 56
Afgelopen 30 dagen: 261
Altijd: 400,820
