Ga door naar hoofdinhoud
Lenovo Ideatab A1000 Wipe Data / Factory Reset (Hard Reset)
Wat je nodig hebt
Video overzicht
  1. Lenovo Ideatab A1000 Wipe Data / Factory Reset (Hard Reset), Lenovo Ideatab A1000 Wipe Data / Factory Reset (Hard Reset): stap 1, afbeelding 1 van 1
    • First of all you can try soft reset from the reset switch. This method does not delete the data from the tablet.
  2. Lenovo Ideatab A1000 Wipe Data / Factory Reset (Hard Reset): stap 2, afbeelding 1 van 3 Lenovo Ideatab A1000 Wipe Data / Factory Reset (Hard Reset): stap 2, afbeelding 2 van 3 Lenovo Ideatab A1000 Wipe Data / Factory Reset (Hard Reset): stap 2, afbeelding 3 van 3
    • Now - hardware reset:
    • Switch off the tablet.
    • Press and hold at the same time Volume UP and Power keys.
    • When the System Recovery screen appears use the Volume Up/Down keys for navigation and the Power On key for OK.
    • Choose "wipe data / factory reset", "Yes -- delete all user data", "reboot system now".
  3. Lenovo Ideatab A1000 Wipe Data / Factory Reset (Hard Reset): stap 3, afbeelding 1 van 1
    • That's all.
Conclusie
47 andere personen hebben deze handleiding voltooid.
ZFix
191.368 Reputatie
330 handleidingen geschreven
Master Techs Lid van Master Techs
Community
321 Leden
1.468 handleidingen geschreven
36 opmerkingen
If device is connected to charger that button combination doesn't work. It goes to hardware test menu.
Pekka Lounatvuori - Antwoord
How to reser chinese language lenova phone
With Chinese phones, you do not need to use other options, and there is no confirmation. The wipe simply starts, and completes by wiping your phone. Read more - http://www.gogorapid.com/how-to-reset-ch...
Rumal Roma - Antwoord
My lenovo a 1000 idea tab's display is gone....no bottom in work...how to reset or fix it
ashiquehossain15 - Antwoord
my lenovo s850 is on meta mode when i press vol down + power button and nothing appear when i press vol up + power button.. the thing is i've tried many button sequence but i just cat get into reset mode or cynogen mode.. :(
wooblegooble92 - Antwoord
My lenovo tab isnt working until it went to some sort of menu using volume buttons but then i actually pressed something and it went to a screen saying "Now send the package you want to apply to the device using adb sideload <filename>" how do i go back to the reboot menu
Albert Einstein - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 48
Afgelopen 30 dagen: 241
Altijd: 400,931
