Ga door naar hoofdinhoud
Lenovo Ideapad Yoga 2 11 Battery Replacement
Wat je nodig hebt
  1. Lenovo Ideapad Yoga 2 11 Battery Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Begin by turning your closed laptop so that you are looking at the bottom panel.
  2. Lenovo Ideapad Yoga 2 11 Battery Replacement: stap 2, afbeelding 1 van 2 Lenovo Ideapad Yoga 2 11 Battery Replacement: stap 2, afbeelding 2 van 2
    • Locate the 10 screws (6mm) around the border of the panel.
    • Using the Torx T5 Screwdriver, remove the screws.
  3. Lenovo Ideapad Yoga 2 11 Battery Replacement: stap 3, afbeelding 1 van 1
    • Now that the screws are removed, gently lift the back panel upwards to detach it from the rest of your laptop.
  4. Lenovo Ideapad Yoga 2 11 Battery Replacement, Battery: stap 4, afbeelding 1 van 2 Lenovo Ideapad Yoga 2 11 Battery Replacement, Battery: stap 4, afbeelding 2 van 2
    • Locate the battery in the bottom right corner.
    • Using a Phillips #000, remove the 6 screws (3.5mm) on the border of the battery and the 7th screw (6.5mm) that is in the center of the battery.
  5. Lenovo Ideapad Yoga 2 11 Battery Replacement: stap 5, afbeelding 1 van 3 Lenovo Ideapad Yoga 2 11 Battery Replacement: stap 5, afbeelding 2 van 3 Lenovo Ideapad Yoga 2 11 Battery Replacement: stap 5, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Locate the cable connecting to the battery. It is located at the top-center of the battery.
    • Use a pair of tweezers and place it so that the tweezer is around the cables. Gently pull the cables towards the battery to disconnect the cable.
  6. Lenovo Ideapad Yoga 2 11 Battery Replacement: stap 6, afbeelding 1 van 2 Lenovo Ideapad Yoga 2 11 Battery Replacement: stap 6, afbeelding 2 van 2
    • There may be tape around the edge of the battery to secure some wires. Use a pair of tweezers to remove the tape so that the wires are no longer attached to the battery.
  7. Lenovo Ideapad Yoga 2 11 Battery Replacement: stap 7, afbeelding 1 van 2 Lenovo Ideapad Yoga 2 11 Battery Replacement: stap 7, afbeelding 2 van 2
    • After you have unscrewed the screws, unplugged the cable, and removed the tape and wires, you can remove the battery from your laptop.
Conclusie
Andria Chen
624 Reputatie
5 handleidingen geschreven
Één opmerking
Excellent instructions makes it easy even for novice
bhimanagouda patil - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 9
Altijd: 1,815
