Ga door naar hoofdinhoud
Lenovo Ideapad S415 Touch RAM Replacement
Wat je nodig hebt
  1. Lenovo Ideapad S415 Touch RAM Replacement, Battery: stap 1, afbeelding 1 van 1
    • Flip laptop over bottom side up.
    • Locate the two battery release switches.
  2. Lenovo Ideapad S415 Touch RAM Replacement: stap 2, afbeelding 1 van 1
    • Use your finger to push the battery release switch labeled "1." The red indicates that the switch is unlocked.
  3. Lenovo Ideapad S415 Touch RAM Replacement: stap 3, afbeelding 1 van 1
    • Use your finger to push the battery switch labeled "2."
  4. Lenovo Ideapad S415 Touch RAM Replacement: stap 4, afbeelding 1 van 1
    • Once both switches are unlocked, the battery will release.
  5. Lenovo Ideapad S415 Touch RAM Replacement: stap 5, afbeelding 1 van 1
    • When replacing the battery make sure the two protruding holes line up with the slot.
    • Carefully remove the battery.
  6. Lenovo Ideapad S415 Touch RAM Replacement, RAM: stap 6, afbeelding 1 van 2 Lenovo Ideapad S415 Touch RAM Replacement, RAM: stap 6, afbeelding 2 van 2
    • Locate the five 6mm black screws on the bottom.
    • Using a Phillips #0 screwdriver, remove all five screws.
  7. Lenovo Ideapad S415 Touch RAM Replacement: stap 7, afbeelding 1 van 2 Lenovo Ideapad S415 Touch RAM Replacement: stap 7, afbeelding 2 van 2
    • Locate the three 4mm silver screws on the bottom area where the battery was removed.
    • Use the Phillips #0 screwdriver to remove all three screws.
  8. Lenovo Ideapad S415 Touch RAM Replacement: stap 8, afbeelding 1 van 3 Lenovo Ideapad S415 Touch RAM Replacement: stap 8, afbeelding 2 van 3 Lenovo Ideapad S415 Touch RAM Replacement: stap 8, afbeelding 3 van 3
    • Locate the four rubber stoppers near each corner of the laptop.
    • Open up the stoppers by lifting each with your hands.
  9. Lenovo Ideapad S415 Touch RAM Replacement: stap 9, afbeelding 1 van 3 Lenovo Ideapad S415 Touch RAM Replacement: stap 9, afbeelding 2 van 3 Lenovo Ideapad S415 Touch RAM Replacement: stap 9, afbeelding 3 van 3
    • Under each of the four stoppers, there will be a 6mm screw.
    • Use the Phillips #0 screwdriver to remove all four screws.
  10. Lenovo Ideapad S415 Touch RAM Replacement: stap 10, afbeelding 1 van 2 Lenovo Ideapad S415 Touch RAM Replacement: stap 10, afbeelding 2 van 2
    • Carefully open up the laptop to reveal the internal components.
  11. Lenovo Ideapad S415 Touch RAM Replacement: stap 11, afbeelding 1 van 3 Lenovo Ideapad S415 Touch RAM Replacement: stap 11, afbeelding 2 van 3 Lenovo Ideapad S415 Touch RAM Replacement: stap 11, afbeelding 3 van 3
    • Locate the RAM.
    • Using your hands gently push up on the two silver clips located on both ends of the RAM.
    • The RAM will spring out. Gently pull it out of the slot.
    • Do not touch the top yellow part of the RAM as this will cause damage.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Alexandria
363 Reputatie
2 handleidingen geschreven
UC Davis, Team S20-G5, Lore Winter 2019 Lid van UC Davis, Team S20-G5, Lore Winter 2019
UCD-LORE-W19S20G5
3 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 11
Altijd: 732
