Ga door naar hoofdinhoud
Lenovo Ideapad S415 Touch Hard Drive Replacement
Wat je nodig hebt
  1. Lenovo Ideapad S415 Touch Hard Drive Replacement, Battery: stap 1, afbeelding 1 van 1
    • Flip laptop over bottom side up.
    • Locate the two battery release switches.
  2. Lenovo Ideapad S415 Touch Hard Drive Replacement: stap 2, afbeelding 1 van 1
    • Use your finger to push the battery release switch labeled "1." The red indicates that the switch is unlocked.
  3. Lenovo Ideapad S415 Touch Hard Drive Replacement: stap 3, afbeelding 1 van 1
    • Use your finger to push the battery switch labeled "2."
  4. Lenovo Ideapad S415 Touch Hard Drive Replacement: stap 4, afbeelding 1 van 1
    • Once both switches are unlocked, the battery will release.
  5. Lenovo Ideapad S415 Touch Hard Drive Replacement: stap 5, afbeelding 1 van 1
    • When replacing the battery make sure the two protruding holes line up with the slot.
    • Carefully remove the battery.
  6. Lenovo Ideapad S415 Touch Hard Drive Replacement, Hard Drive: stap 6, afbeelding 1 van 2 Lenovo Ideapad S415 Touch Hard Drive Replacement, Hard Drive: stap 6, afbeelding 2 van 2
    • Locate the five black screws on the back.
    • Use a Phillips #0 screwdriver to remove all five black 6 mm screws.
  7. Lenovo Ideapad S415 Touch Hard Drive Replacement: stap 7, afbeelding 1 van 2 Lenovo Ideapad S415 Touch Hard Drive Replacement: stap 7, afbeelding 2 van 2
    • Locate the three silver screws underneath the battery.
    • Use the Phillips #0 screwdriver to remove all three 4 mm screws.
  8. Lenovo Ideapad S415 Touch Hard Drive Replacement: stap 8, afbeelding 1 van 3 Lenovo Ideapad S415 Touch Hard Drive Replacement: stap 8, afbeelding 2 van 3 Lenovo Ideapad S415 Touch Hard Drive Replacement: stap 8, afbeelding 3 van 3
    • Locate the four rubber stoppers near each corner of the laptop.
    • Open up the stopper with your hands.
    • Use the Phillips #0 screwdriver to remove the 6 mm screws underneath all four stoppers.
  9. Lenovo Ideapad S415 Touch Hard Drive Replacement: stap 9, afbeelding 1 van 1
    • Open the laptop carefully.
  10. Lenovo Ideapad S415 Touch Hard Drive Replacement: stap 10, afbeelding 1 van 2 Lenovo Ideapad S415 Touch Hard Drive Replacement: stap 10, afbeelding 2 van 2
    • Locate the hard drive.
    • Use the Phillips #0 screwdriver to remove the two 4 mm screws that are holding the hard drive in place.
  11. Lenovo Ideapad S415 Touch Hard Drive Replacement: stap 11, afbeelding 1 van 1
    • The hard drive is now removed from the laptop.
  12. Lenovo Ideapad S415 Touch Hard Drive Replacement: stap 12, afbeelding 1 van 2 Lenovo Ideapad S415 Touch Hard Drive Replacement: stap 12, afbeelding 2 van 2
    • Once the hard drive is removed, locate the four screws that hold the metal frame to the hard drive.
    • Use the Phillips #0 screwdriver to remove the 4 mm silver screws on all sides.
Conclusie
Casey Zhang
315 Reputatie
2 handleidingen geschreven
UC Davis, Team S20-G5, Lore Winter 2019 Lid van UC Davis, Team S20-G5, Lore Winter 2019
UCD-LORE-W19S20G5
3 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 13
Altijd: 473
