Ga door naar hoofdinhoud
Lenovo Ideapad S415 Touch Fan Replacement
Wat je nodig hebt
  1. Lenovo Ideapad S415 Touch Fan Replacement, Battery: stap 1, afbeelding 1 van 1
    • Flip laptop over bottom side up.
    • Locate the two battery release switches.
  2. Lenovo Ideapad S415 Touch Fan Replacement: stap 2, afbeelding 1 van 1
    • Use your finger to push the battery release switch labeled "1." The red indicates that the switch is unlocked.
  3. Lenovo Ideapad S415 Touch Fan Replacement: stap 3, afbeelding 1 van 1
    • Use your finger to push the battery switch labeled "2."
  4. Lenovo Ideapad S415 Touch Fan Replacement: stap 4, afbeelding 1 van 1
    • Once both switches are unlocked, the battery will release.
  5. Lenovo Ideapad S415 Touch Fan Replacement: stap 5, afbeelding 1 van 1
    • When replacing the battery make sure the two protruding holes line up with the slot.
    • Carefully remove the battery.
  6. Lenovo Ideapad S415 Touch Fan Replacement, Fan: stap 6, afbeelding 1 van 2 Lenovo Ideapad S415 Touch Fan Replacement, Fan: stap 6, afbeelding 2 van 2
    • Locate the five 6mm black screws on the bottom.
    • Using a Phillips #0 screwdriver, remove all five black screws.
  7. Lenovo Ideapad S415 Touch Fan Replacement: stap 7, afbeelding 1 van 2 Lenovo Ideapad S415 Touch Fan Replacement: stap 7, afbeelding 2 van 2
    • Locate the three 4mm silver screws on the bottom area where the battery was removed.
    • Using the Phillips #0 screwdriver, remove all three silver screws.
  8. Lenovo Ideapad S415 Touch Fan Replacement: stap 8, afbeelding 1 van 3 Lenovo Ideapad S415 Touch Fan Replacement: stap 8, afbeelding 2 van 3 Lenovo Ideapad S415 Touch Fan Replacement: stap 8, afbeelding 3 van 3
    • Locate the four rubber stoppers near each corner of the laptop.
    • Open up the stoppers by lifting each with your fingers.
  9. Lenovo Ideapad S415 Touch Fan Replacement: stap 9, afbeelding 1 van 3 Lenovo Ideapad S415 Touch Fan Replacement: stap 9, afbeelding 2 van 3 Lenovo Ideapad S415 Touch Fan Replacement: stap 9, afbeelding 3 van 3
    • Under each of the four stoppers, there will be a 6mm screw.
    • Use the Phillips #0 screwdriver to remove all four screws.
  10. Lenovo Ideapad S415 Touch Fan Replacement: stap 10, afbeelding 1 van 2 Lenovo Ideapad S415 Touch Fan Replacement: stap 10, afbeelding 2 van 2
    • Carefully open up the laptop to reveal the internal components.
  11. Lenovo Ideapad S415 Touch Fan Replacement: stap 11, afbeelding 1 van 2 Lenovo Ideapad S415 Touch Fan Replacement: stap 11, afbeelding 2 van 2
    • Locate the silver 6mm screw on the top of the fan
    • Locate the silver 4mm screw on the bottom of the fan
    • Use a Phillips #0 screwdriver to remove both screws.
  12. Lenovo Ideapad S415 Touch Fan Replacement: stap 12, afbeelding 1 van 2 Lenovo Ideapad S415 Touch Fan Replacement: stap 12, afbeelding 2 van 2
    • Locate the fan power connector.
    • Use a spudger or your hands to disconnect the fan power connector from its port.
  13. Lenovo Ideapad S415 Touch Fan Replacement: stap 13, afbeelding 1 van 2 Lenovo Ideapad S415 Touch Fan Replacement: stap 13, afbeelding 2 van 2
    • Once the fan power connector is disconnected, lift up the bronze heatsink and pull the wires out from underneath it.
    • Lift up the fan and pull free.
Conclusie
Alexandria
363 Reputatie
2 handleidingen geschreven
UC Davis, Team S20-G5, Lore Winter 2019 Lid van UC Davis, Team S20-G5, Lore Winter 2019
UCD-LORE-W19S20G5
3 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 192
