Ga door naar hoofdinhoud
Lenovo Ideapad S415 Touch Battery Replacement
  1. Lenovo Ideapad S415 Touch Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Flip laptop over bottom side up.
    • Locate the two battery release switches.
  2. Lenovo Ideapad S415 Touch Battery Replacement: stap 2, afbeelding 1 van 1
    • Use your finger to push the battery release switch labeled "1." The red indicates that the switch is unlocked.
  3. Lenovo Ideapad S415 Touch Battery Replacement: stap 3, afbeelding 1 van 1
    • Use your finger to push the battery switch labeled "2."
  4. Lenovo Ideapad S415 Touch Battery Replacement: stap 4, afbeelding 1 van 1
    • Once both switches are unlocked, the battery will release.
  5. Lenovo Ideapad S415 Touch Battery Replacement: stap 5, afbeelding 1 van 1
    • When replacing the battery make sure the two protruding holes line up with the slot.
    • Carefully remove the battery.
Conclusie
Casey Zhang
315 Reputatie
2 handleidingen geschreven
UC Davis, Team S20-G5, Lore Winter 2019 Lid van UC Davis, Team S20-G5, Lore Winter 2019
UCD-LORE-W19S20G5
3 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 9
Altijd: 287
