Ga door naar hoofdinhoud
Lenovo Ideapad Flex 4-1570 Touchpad Replacement
Wat je nodig hebt
  1. Lenovo Ideapad Flex 4-1570 Touchpad Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Shut down and unplug your laptop before you begin.
  2. Lenovo Ideapad Flex 4-1570 Touchpad Replacement: stap 2, afbeelding 1 van 1
    • Remove the nine 6 mm screws using a T5 Torx Screwdriver.
    • Remove the two 10 mm screws using a T5 Torx Screwdriver.
  3. Lenovo Ideapad Flex 4-1570 Touchpad Replacement: stap 3, afbeelding 1 van 1
    • Use a plastic opening tool to carefully pry off the back cover.
    • Remove the back cover.
  4. Lenovo Ideapad Flex 4-1570 Touchpad Replacement, Battery: stap 4, afbeelding 1 van 2 Lenovo Ideapad Flex 4-1570 Touchpad Replacement, Battery: stap 4, afbeelding 2 van 2
    • Disconnect the battery by using a plastic opening tool or your fingers to push the connector towards the battery.
    • Do not pry or pull on the socket itself or you risk damaging the motherboard.
  5. Lenovo Ideapad Flex 4-1570 Touchpad Replacement: stap 5, afbeelding 1 van 1
    • Remove the three 4 mm screws using a T5 Torx Screwdriver.
  6. Lenovo Ideapad Flex 4-1570 Touchpad Replacement: stap 6, afbeelding 1 van 1
    • Remove the battery.
  7. Lenovo Ideapad Flex 4-1570 Touchpad Replacement, Touchpad: stap 7, afbeelding 1 van 1
    • Locate the touch pad and remove the two 3 mm screws using a T5 Torx Screwdriver.
  8. Lenovo Ideapad Flex 4-1570 Touchpad Replacement: stap 8, afbeelding 1 van 1
    • Disconnect the touch pad chip from the motherboard.
  9. Lenovo Ideapad Flex 4-1570 Touchpad Replacement: stap 9, afbeelding 1 van 1
    • Disconnect the bronze piece of tape from touch pad and set it off to the side.
  10. Lenovo Ideapad Flex 4-1570 Touchpad Replacement: stap 10, afbeelding 1 van 2 Lenovo Ideapad Flex 4-1570 Touchpad Replacement: stap 10, afbeelding 2 van 2
    • Open the laptop and, with the assistance of the iFixit blue plastic tool, guide the touch pad through, it should come out on its own.
Conclusie
Isaiah Vang
669 Reputatie
6 handleidingen geschreven
UW Stout, Team S6-G6, Ogden Fall 2018 Lid van UW Stout, Team S6-G6, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G6
4 Leden
16 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 10
Altijd: 548
