Inleiding
If you are unable to move the mouse and it is overly sensitive, use this guide to replace your touchpad.
Wat je nodig hebt
Disconnect the battery by using a plastic opening tool or your fingers to push the connector towards the battery.
Locate the touch pad and remove the two 3 mm screws using a T5 Torx Screwdriver.
Bijna klaar!
Conclusie
