Ga door naar hoofdinhoud
Lenovo Ideapad Flex 4-1570 RAM Replacement
Wat je nodig hebt
  1. Lenovo Ideapad Flex 4-1570 RAM Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Shut down and unplug your laptop before you begin.
  2. Lenovo Ideapad Flex 4-1570 RAM Replacement: stap 2, afbeelding 1 van 1
    • Remove the nine 6 mm screws using a T5 Torx Screwdriver.
    • Remove the two 10 mm screws using a T5 Torx Screwdriver.
  3. Lenovo Ideapad Flex 4-1570 RAM Replacement: stap 3, afbeelding 1 van 1
    • Use a plastic opening tool to carefully pry off the back cover.
    • Remove the back cover.
  4. Lenovo Ideapad Flex 4-1570 RAM Replacement, RAM: stap 4, afbeelding 1 van 1
    • Gently remove the RAM cover with a spudger.
    • Although a metal spudger is shown in the photo, an ESD-safe nylon spudger is recommended.
  5. Lenovo Ideapad Flex 4-1570 RAM Replacement: stap 5, afbeelding 1 van 1
    • Do not attempt to pull the RAM out without first pulling up the metal release brackets.
    • Gently remove the RAM by pulling up the metal release brackets, pushing the RAM forward out of its port, and lifting it up and out.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 191
