Ga door naar hoofdinhoud
Lenovo Ideapad Flex 4-1570 Display Replacement
Wat je nodig hebt
  1. Lenovo Ideapad Flex 4-1570 Display Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Shut down and unplug your laptop before you begin.
  2. Lenovo Ideapad Flex 4-1570 Display Replacement: stap 2, afbeelding 1 van 1
    • Remove the nine 6 mm screws using a T5 Torx Screwdriver.
    • Remove the two 10 mm screws using a T5 Torx Screwdriver.
  3. Lenovo Ideapad Flex 4-1570 Display Replacement: stap 3, afbeelding 1 van 1
    • Use a plastic opening tool to carefully pry off the back cover.
    • Remove the back cover.
  4. Lenovo Ideapad Flex 4-1570 Display Replacement, Display: stap 4, afbeelding 1 van 2 Lenovo Ideapad Flex 4-1570 Display Replacement, Display: stap 4, afbeelding 2 van 2
    • Use an opening tool to remove the three hinge bezels.
  5. Lenovo Ideapad Flex 4-1570 Display Replacement: stap 5, afbeelding 1 van 1
    • Remove the four 4 mm screws (two on each hinge) using a T5 Torx screwdriver.
  6. Lenovo Ideapad Flex 4-1570 Display Replacement: stap 6, afbeelding 1 van 3 Lenovo Ideapad Flex 4-1570 Display Replacement: stap 6, afbeelding 2 van 3 Lenovo Ideapad Flex 4-1570 Display Replacement: stap 6, afbeelding 3 van 3
    • Attach a suction handle to the corner of the display, then wedge the blade of a Jimmy between the display and its housing.
    • While sliding the Jimmy around the perimeter, place opening picks in the gap you created at regular intervals.
    • Once you've worked around the perimeter, lightly pull on the suction handle while gently prying with an opening tool until the display releases.
  7. Lenovo Ideapad Flex 4-1570 Display Replacement: stap 7, afbeelding 1 van 1
    • Use a T5 Torx screwdriver to remove the six 4 mm screws (three on each hinge) securing the hinges.
  8. Lenovo Ideapad Flex 4-1570 Display Replacement: stap 8, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Use tweezers to remove the rubber stoppers in both hinges.
  9. Lenovo Ideapad Flex 4-1570 Display Replacement: stap 9, afbeelding 1 van 1
    • Remove the black foam over the black and white cords, to the left of the Wi-Fi card, using tweezers.
  10. Lenovo Ideapad Flex 4-1570 Display Replacement: stap 10, afbeelding 1 van 1
    • Disconnect the black cable near the fan using tweezers.
  11. Lenovo Ideapad Flex 4-1570 Display Replacement: stap 11, afbeelding 1 van 1
    • Remove the display from the rest of the computer.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 258
