Inleiding
If your wireless networking card is not working or needs to be replaced / upgraded, follow this guide.
Wat je nodig hebt
Start by removing the feet near the LCD hinge of the laptop to reveal two screws.
Using a Phillips #1 screwdriver, remove the top five (30 mm) screws underneath the battery.
Locate the wireless card. It is located above the black ribbon cable, underneath the battery terminals.
The wireless card has two antennas (black and white cables) that are attached to other parts of the laptop.
There are two (30 mm) screws attached to the wireless card underneath the antenna. Remove both of these with your screwdriver (bit PH1).
Once the screws are removed, the wireless card will tilt upwards. Firmly grab the card with one hand and pull it slowly, diagonally, out of the socket.
To replace this card with a new wireless card, put the contacts back into the socket. The wireless card should be sitting at a 45 degree angle.
To seat the wireless card, put the two screws back into the card. It should be flush against the base of the laptop.
Line up the white antenna back in the original (left) terminal. Push the antenna gently onto the wireless adapter with one finger. Give it a small tug to ensure it is connected firmly.
Do the same with the black antenna, snapping it onto the right antenna port.
3 andere personen hebben deze handleiding voltooid.
Één opmerking
I would like to upgrade my Lenovo Flex 15, model 20309, wifi card. It says I have wireless-N 7260 and I would like it upgraded to a fast dual band card. I am having trouble finding a wifi card that I am confident will be compatible with my laptop. Most of the 7260’s say they do not work with Lenovo. Any help is very much appreciated!
