Ga door naar hoofdinhoud
Lenovo Ideapad Flex 15 USB Header Adaptor Replacement
Wat je nodig hebt
  1. Lenovo Ideapad Flex 15 USB Header Adaptor Replacement, Bottom Panel: stap 1, afbeelding 1 van 2 Lenovo Ideapad Flex 15 USB Header Adaptor Replacement, Bottom Panel: stap 1, afbeelding 2 van 2
    • Start by removing the feet near the LCD hinge of the laptop to reveal two screws.
    • Using a Phillips #1 screwdriver, remove the top five (30 mm) screws underneath the battery.
  2. Lenovo Ideapad Flex 15 USB Header Adaptor Replacement: stap 2, afbeelding 1 van 2 Lenovo Ideapad Flex 15 USB Header Adaptor Replacement: stap 2, afbeelding 2 van 2
    • Once both feet are removed, two (40 mm) screws will reveal themselves. Unscrew these.
  3. Lenovo Ideapad Flex 15 USB Header Adaptor Replacement: stap 3, afbeelding 1 van 3 Lenovo Ideapad Flex 15 USB Header Adaptor Replacement: stap 3, afbeelding 2 van 3 Lenovo Ideapad Flex 15 USB Header Adaptor Replacement: stap 3, afbeelding 3 van 3
    • Working your way around the outer edges of the Flex 15, remove the 8 (30 mm) outer screws.
  4. Lenovo Ideapad Flex 15 USB Header Adaptor Replacement: stap 4, afbeelding 1 van 1
    • Remove the one (40 mm) screw in the middle of the Flex 15.
  5. Lenovo Ideapad Flex 15 USB Header Adaptor Replacement: stap 5, afbeelding 1 van 3 Lenovo Ideapad Flex 15 USB Header Adaptor Replacement: stap 5, afbeelding 2 van 3 Lenovo Ideapad Flex 15 USB Header Adaptor Replacement: stap 5, afbeelding 3 van 3
    • Using a plastic opening tool, make your way around the edge of the laptop.
    • There is a visible line between the bottom shell of the laptop and the laptop body itself.
  6. Lenovo Ideapad Flex 15 USB Header Adaptor Replacement: stap 6, afbeelding 1 van 2 Lenovo Ideapad Flex 15 USB Header Adaptor Replacement: stap 6, afbeelding 2 van 2
    • Make sure to pry evenly around this edge and only remove the bottom of the laptop when it is fully loose.
    • Using excessive force may break the bottom plastic. There are plastic clips along the edge of the laptop.
  7. Lenovo Ideapad Flex 15 USB Header Adaptor Replacement, USB Header Adaptor: stap 7, afbeelding 1 van 2 Lenovo Ideapad Flex 15 USB Header Adaptor Replacement, USB Header Adaptor: stap 7, afbeelding 2 van 2
    • Locate the large blue circuit board on the leftmost side of the Flex 15.
    • This board is connected in two ways, by both a screw and a ribbon cable.
  8. Lenovo Ideapad Flex 15 USB Header Adaptor Replacement: stap 8, afbeelding 1 van 2 Lenovo Ideapad Flex 15 USB Header Adaptor Replacement: stap 8, afbeelding 2 van 2
    • The large black ribbon cable is attached to a header. With a blue opening tool, flip up the ZIF (zero insertion force) connector, then pry the header from a 0 degree angle to a 90 degree angle. Be sure not to snap the header while doing it, it is very delicate.
    • Once the ribbon cable is freed, gently pull it out of the header.
  9. Lenovo Ideapad Flex 15 USB Header Adaptor Replacement: stap 9, afbeelding 1 van 2 Lenovo Ideapad Flex 15 USB Header Adaptor Replacement: stap 9, afbeelding 2 van 2
    • Locate the (20 mm) screws with the orange ring and the arrow on the PCB pointing to it. Remove these screws.
    • Once freed, pull the assembly upwards, away from the computer.
Conclusie
Brent
804 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team 6-6, Bhusal Spring 2016 Lid van UMass Dartmouth, Team 6-6, Bhusal Spring 2016
UMASSD-BHUSAL-S16S6G6
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 550
