Ga door naar hoofdinhoud
Lenovo Ideapad Flex 15 RAM Replacement
Wat je nodig hebt
  1. Lenovo Ideapad Flex 15 RAM Replacement, Bottom Panel: stap 1, afbeelding 1 van 2 Lenovo Ideapad Flex 15 RAM Replacement, Bottom Panel: stap 1, afbeelding 2 van 2
    • Start by removing the feet near the LCD hinge of the laptop to reveal two screws.
    • Using a Phillips #1 screwdriver, remove the top five (30 mm) screws underneath the battery.
  2. Lenovo Ideapad Flex 15 RAM Replacement: stap 2, afbeelding 1 van 2 Lenovo Ideapad Flex 15 RAM Replacement: stap 2, afbeelding 2 van 2
    • Once both feet are removed, two (40 mm) screws will reveal themselves. Unscrew these.
  3. Lenovo Ideapad Flex 15 RAM Replacement: stap 3, afbeelding 1 van 3 Lenovo Ideapad Flex 15 RAM Replacement: stap 3, afbeelding 2 van 3 Lenovo Ideapad Flex 15 RAM Replacement: stap 3, afbeelding 3 van 3
    • Working your way around the outer edges of the Flex 15, remove the 8 (30 mm) outer screws.
  4. Lenovo Ideapad Flex 15 RAM Replacement: stap 4, afbeelding 1 van 1
    • Remove the one (40 mm) screw in the middle of the Flex 15.
  5. Lenovo Ideapad Flex 15 RAM Replacement: stap 5, afbeelding 1 van 3 Lenovo Ideapad Flex 15 RAM Replacement: stap 5, afbeelding 2 van 3 Lenovo Ideapad Flex 15 RAM Replacement: stap 5, afbeelding 3 van 3
    • Using a plastic opening tool, make your way around the edge of the laptop.
    • There is a visible line between the bottom shell of the laptop and the laptop body itself.
  6. Lenovo Ideapad Flex 15 RAM Replacement: stap 6, afbeelding 1 van 2 Lenovo Ideapad Flex 15 RAM Replacement: stap 6, afbeelding 2 van 2
    • Make sure to pry evenly around this edge and only remove the bottom of the laptop when it is fully loose.
    • Using excessive force may break the bottom plastic. There are plastic clips along the edge of the laptop.
  7. Lenovo Ideapad Flex 15 RAM Replacement, RAM: stap 7, afbeelding 1 van 2 Lenovo Ideapad Flex 15 RAM Replacement, RAM: stap 7, afbeelding 2 van 2
    • Once open, locate the RAM stick below the fan on the bottom right corner of the Flex 15.
    • At the same time, using two hands, pull both clips away from the RAM module.
  8. Lenovo Ideapad Flex 15 RAM Replacement: stap 8, afbeelding 1 van 2 Lenovo Ideapad Flex 15 RAM Replacement: stap 8, afbeelding 2 van 2
    • The RAM stick should start to tilt upwards. Once you see this, pull the stick diagonally towards the top of the laptop.
    • Be careful and do not apply extra pressure on the RAM.
    • If you feel that it will snap, pull the clips apart farther to loosen the RAM connection. Then try again.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Brent
804 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team 6-6, Bhusal Spring 2016 Lid van UMass Dartmouth, Team 6-6, Bhusal Spring 2016
UMASSD-BHUSAL-S16S6G6
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 24
Altijd: 3,061
