Ga door naar hoofdinhoud
Lenovo Ideapad 330-15ARR Fan Assembly Replacement
Wat je nodig hebt
  1. Lenovo Ideapad 330-15ARR Fan Assembly Replacement, Lower Case: stap 1, afbeelding 1 van 1
    • Remove all Phillips #0 screws securing the case to the laptop.
  2. Lenovo Ideapad 330-15ARR Fan Assembly Replacement: stap 2, afbeelding 1 van 2 Lenovo Ideapad 330-15ARR Fan Assembly Replacement: stap 2, afbeelding 2 van 2
    • Pry all edges off of the laptop with the opening tool until the lower case releases.
    • Remove the lower case.
  3. Lenovo Ideapad 330-15ARR Fan Assembly Replacement, Fan Assembly: stap 3, afbeelding 1 van 2 Lenovo Ideapad 330-15ARR Fan Assembly Replacement, Fan Assembly: stap 3, afbeelding 2 van 2
    • Unscrew all three captive screws attaching the heat sink to the motherboard with a Phillips #0 screwdriver.
    • These screws stay attached to the heatsink, so do not attempt to remove them.
  4. Lenovo Ideapad 330-15ARR Fan Assembly Replacement: stap 4, afbeelding 1 van 2 Lenovo Ideapad 330-15ARR Fan Assembly Replacement: stap 4, afbeelding 2 van 2
    • Remove the three Phillips #0 screws securing the fan assembly.
  5. Lenovo Ideapad 330-15ARR Fan Assembly Replacement: stap 5, afbeelding 1 van 3 Lenovo Ideapad 330-15ARR Fan Assembly Replacement: stap 5, afbeelding 2 van 3 Lenovo Ideapad 330-15ARR Fan Assembly Replacement: stap 5, afbeelding 3 van 3
    • Take the wires in your hand, and firmly but gently pull it out of its port.
    • Lift the fan assembly out of the device.
Conclusie
Brayden Fleming
479 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 18
Altijd: 312
