Ga door naar hoofdinhoud
Lenovo Ideapad 320-17IKB Heat Sink Replacement
Wat je nodig hebt
  1. Lenovo Ideapad 320-17IKB Heat Sink Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Turn off and unplug the computer.
    • Flip the laptop over so that the back panel is facing upwards.
  2. Lenovo Ideapad 320-17IKB Heat Sink Replacement: stap 2, afbeelding 1 van 2 Lenovo Ideapad 320-17IKB Heat Sink Replacement: stap 2, afbeelding 2 van 2
    • Remove fourteen 7mm Phillips #00 screws from the back panel.
  3. Lenovo Ideapad 320-17IKB Heat Sink Replacement: stap 3, afbeelding 1 van 1
    • Carefully remove the optical drive by pulling the bezel away from the laptop.
  4. Lenovo Ideapad 320-17IKB Heat Sink Replacement: stap 4, afbeelding 1 van 2 Lenovo Ideapad 320-17IKB Heat Sink Replacement: stap 4, afbeelding 2 van 2
    • Use your fingers or an opening tool to gently remove the back panel from the bottom of the laptop.
    • Lay both sides of the laptop next to each other.
  5. Lenovo Ideapad 320-17IKB Heat Sink Replacement, Battery: stap 5, afbeelding 1 van 2 Lenovo Ideapad 320-17IKB Heat Sink Replacement, Battery: stap 5, afbeelding 2 van 2
    • Remove five 7mm Phillips #0 screws from the battery holder.
  6. Lenovo Ideapad 320-17IKB Heat Sink Replacement: stap 6, afbeelding 1 van 2 Lenovo Ideapad 320-17IKB Heat Sink Replacement: stap 6, afbeelding 2 van 2
    • Pinch the connecting cord with one hand and pry the battery connector with the other hand, while gently pulling the connector straight out and towards the bottom edge of the base.
    • When removing the battery, use care to keep it flat and do not open the battery because it can result in fire or explosion.
  7. Lenovo Ideapad 320-17IKB Heat Sink Replacement, Fan: stap 7, afbeelding 1 van 2 Lenovo Ideapad 320-17IKB Heat Sink Replacement, Fan: stap 7, afbeelding 2 van 2
    • Remove five 7mm Phillips #00 screws from the cooling fan.
  8. Lenovo Ideapad 320-17IKB Heat Sink Replacement: stap 8, afbeelding 1 van 3 Lenovo Ideapad 320-17IKB Heat Sink Replacement: stap 8, afbeelding 2 van 3 Lenovo Ideapad 320-17IKB Heat Sink Replacement: stap 8, afbeelding 3 van 3
    • Gently lift the fan assembly out of the laptop.
    • Gently remove the connecting wires from the exterior of the fan by slowly "weaving" the cord between the ridges of the fan.
  9. Lenovo Ideapad 320-17IKB Heat Sink Replacement, Heat Sink: stap 9, afbeelding 1 van 3 Lenovo Ideapad 320-17IKB Heat Sink Replacement, Heat Sink: stap 9, afbeelding 2 van 3 Lenovo Ideapad 320-17IKB Heat Sink Replacement, Heat Sink: stap 9, afbeelding 3 van 3
    • Gently lift and remove the heat sink and set it aside.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Kristen Gismondi
82.103 Reputatie
200 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
17.228 handleidingen geschreven
Één opmerking
Guys, did you notice the hole in the heat sink just above the processor? Doesn't it make the heatsink less effective?
Neeraj - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 6
Altijd: 478
