Ga door naar hoofdinhoud
Lenovo Ideapad 320-17IKB Fan Replacement
Wat je nodig hebt
  1. Lenovo Ideapad 320-17IKB Fan Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Turn off and unplug the computer.
    • Flip the laptop over so that the back panel is facing upwards.
  2. Lenovo Ideapad 320-17IKB Fan Replacement: stap 2, afbeelding 1 van 2 Lenovo Ideapad 320-17IKB Fan Replacement: stap 2, afbeelding 2 van 2
    • Remove fourteen 7mm Phillips #00 screws from the back panel.
  3. Lenovo Ideapad 320-17IKB Fan Replacement: stap 3, afbeelding 1 van 1
    • Carefully remove the optical drive by pulling the bezel away from the laptop.
  4. Lenovo Ideapad 320-17IKB Fan Replacement: stap 4, afbeelding 1 van 2 Lenovo Ideapad 320-17IKB Fan Replacement: stap 4, afbeelding 2 van 2
    • Use your fingers or an opening tool to gently remove the back panel from the bottom of the laptop.
    • Lay both sides of the laptop next to each other.
  5. Lenovo Ideapad 320-17IKB Fan Replacement, Battery: stap 5, afbeelding 1 van 2 Lenovo Ideapad 320-17IKB Fan Replacement, Battery: stap 5, afbeelding 2 van 2
    • Remove five 7mm Phillips #0 screws from the battery holder.
  6. Lenovo Ideapad 320-17IKB Fan Replacement: stap 6, afbeelding 1 van 2 Lenovo Ideapad 320-17IKB Fan Replacement: stap 6, afbeelding 2 van 2
    • Pinch the connecting cord with one hand and pry the battery connector with the other hand, while gently pulling the connector straight out and towards the bottom edge of the base.
    • When removing the battery, use care to keep it flat and do not open the battery because it can result in fire or explosion.
  7. Lenovo Ideapad 320-17IKB Fan Replacement, Fan: stap 7, afbeelding 1 van 2 Lenovo Ideapad 320-17IKB Fan Replacement, Fan: stap 7, afbeelding 2 van 2
    • Remove five 7mm Phillips #00 screws from the cooling fan.
  8. Lenovo Ideapad 320-17IKB Fan Replacement: stap 8, afbeelding 1 van 3 Lenovo Ideapad 320-17IKB Fan Replacement: stap 8, afbeelding 2 van 3 Lenovo Ideapad 320-17IKB Fan Replacement: stap 8, afbeelding 3 van 3
    • Gently lift the fan assembly out of the laptop.
    • Gently remove the connecting wires from the exterior of the fan by slowly "weaving" the cord between the ridges of the fan.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Kristen Gismondi
82.362 Reputatie
200 handleidingen geschreven
iFixit Lid van iFixit
Staff
136 Leden
17.303 handleidingen geschreven
Één opmerking
Very helpful instructions. However, Step 6 indicates that you should remove 5 screws, but really you only need the 2 on the left that are actually connecting the fan to the system board, the rest are unnecessary. In fact, the machine I replaced this on only had the one screw in the top-left.
Jeff Breuer - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 22
Altijd: 785
