Ga door naar hoofdinhoud
Lenovo Ideapad 320-15IAP Memory RAM Replacement
Wat je nodig hebt
  1. Lenovo Ideapad 320-15IAP Memory RAM Replacement, Memory RAM: stap 1, afbeelding 1 van 3 Lenovo Ideapad 320-15IAP Memory RAM Replacement, Memory RAM: stap 1, afbeelding 2 van 3 Lenovo Ideapad 320-15IAP Memory RAM Replacement, Memory RAM: stap 1, afbeelding 3 van 3
    • Unscrew thirteen 6.5mm screws from the back panel with the Phillips #0 screwdriver.
    • Pull the CD tray out with an opening tool once all of the screws are removed.
    • Use the opening tool to pull the case off the laptop by prying up the back panel along the edges of the computer. It helps to start from the "DVD drive" slot.
  2. Lenovo Ideapad 320-15IAP Memory RAM Replacement: stap 2, afbeelding 1 van 2 Lenovo Ideapad 320-15IAP Memory RAM Replacement: stap 2, afbeelding 2 van 2
    • Remove the silver RAM cover by lifting it directly up.
    • When reinserting, the bump on the side of the RAM cover should be facing left.
  3. Lenovo Ideapad 320-15IAP Memory RAM Replacement: stap 3, afbeelding 1 van 2 Lenovo Ideapad 320-15IAP Memory RAM Replacement: stap 3, afbeelding 2 van 2
    • Gently pull the metal holders on each side of the memory card away from each other and the card should pop up to rest at an angle to the motherboard.
    • Pull the memory card straight out of its socket with respect to the angle it now rests.
    • When reinserting the replacement RAM card, be sure to slide it in gently at the same angle at which the old one rested, then press the outer edge down until the clips on either side have clasped around it.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 27
Afgelopen 30 dagen: 106
Altijd: 4,134
