Ga door naar hoofdinhoud
Lenovo Ideapad 320-15IAP Hard Drive Replacement
Wat je nodig hebt
  1. Lenovo Ideapad 320-15IAP Hard Drive Replacement, Hard Drive: stap 1, afbeelding 1 van 2 Lenovo Ideapad 320-15IAP Hard Drive Replacement, Hard Drive: stap 1, afbeelding 2 van 2
    • Using a Phillips #0 screwdriver, unscrew all thirteen 6.5 mm screws from the back panel.
  2. Lenovo Ideapad 320-15IAP Hard Drive Replacement: stap 2, afbeelding 1 van 2 Lenovo Ideapad 320-15IAP Hard Drive Replacement: stap 2, afbeelding 2 van 2
    • Remove the CD reader with an opening tool. It is possible you have to apply a substantial amount of force so watch your fingers while doing so.
    • Lift the cover using the opening tool on different spots along the side of the laptop.
  3. Lenovo Ideapad 320-15IAP Hard Drive Replacement: stap 3, afbeelding 1 van 1
    • Remove the hard drive by inserting your finger under the highlighted area, then pushing up then pulling left to remove the drive.
    • Remove the adapter from the drive, then insert the new drive into the adapter.
    • To insert the new drive, gently place it into the enclosure for the hard drive and push carefully into the SATA slot.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 23
Altijd: 1,215
